Ridgid Circular Saw R3205 Spindle Lock Replacement
  1. Ridgid Circular Saw R3205 Spindle Lock Replacement, Blade: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ridgid Circular Saw R3205 Spindle Lock Replacement, Blade: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press the black spindle lock and hold it down.
    • While keeping the spindle lock pressed down use a 6mm allen wrench to remove the 5/16-18 x 0.55 inch screw.
  2. Ridgid Circular Saw R3205 Spindle Lock Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Release the spindle lock and remove the outer flange by lifting it off the output shaft.
  3. Ridgid Circular Saw R3205 Spindle Lock Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ridgid Circular Saw R3205 Spindle Lock Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ridgid Circular Saw R3205 Spindle Lock Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the outer flange removed retract the lower blade guard into the upper blade guard housing by pushing on the black lever.
    • Slide the blade out of from the bottom of the saw.
  4. Ridgid Circular Saw R3205 Spindle Lock Replacement, Lower Blade Guard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ridgid Circular Saw R3205 Spindle Lock Replacement, Lower Blade Guard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a prying tool or your fingers to remove the inner flange.
  5. Ridgid Circular Saw R3205 Spindle Lock Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ridgid Circular Saw R3205 Spindle Lock Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ridgid Circular Saw R3205 Spindle Lock Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the external retaining ring with a screwdriver by expanding it and then prying it out.
  6. Ridgid Circular Saw R3205 Spindle Lock Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After removing the external retaining ring, remove (OD50 x ID42 x 0.8t) washer.
  7. Ridgid Circular Saw R3205 Spindle Lock Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ridgid Circular Saw R3205 Spindle Lock Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the lower blade guard after removing the washer.
  8. Ridgid Circular Saw R3205 Spindle Lock Replacement, Spindle Lock: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the (M3 x 12 mm) screw using a phillips head screwdriver.
  9. Ridgid Circular Saw R3205 Spindle Lock Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Leave the rubber dust cover below the removed screw.
  10. Ridgid Circular Saw R3205 Spindle Lock Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ridgid Circular Saw R3205 Spindle Lock Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ridgid Circular Saw R3205 Spindle Lock Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull out the Spindle Lock.
Joshua Caron
crwdns2935283:004/05/19crwdne2935283:0
792 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S5-G2, Julie Spring 2019 crwdns2935289:0UMass Dartmouth, Team S5-G2, Julie Spring 2019crwdne2935289:0
UMASSD-JULIE-S19S5G2
crwdns2942667:0crwdne2942667:0 1,720
