The lower blade guard on a circular saw is to keep the user safe. The lower blade guard protects the blade from getting damaged and also protects the user from getting cut by the saw. If the lower blade guard is damaged (bent or broken) the guard should be replaced because you could be injured if the saw malfuctions. Replacing the lower blade guard is moderatly easy and doesn’t require any steps that are too complicated.
Press the black spindle lock and hold it down.
While keeping the spindle lock pressed down use a 6mm allen wrench to remove the 5/16-18 x 0.55 inch screw.
Release the spindle lock and remove the outer flange by lifting it off the output shaft.
With the outer flange removed retract the lower blade guard into the upper blade guard housing by pushing on the black lever.
Slide the blade out of from the bottom of the saw.
Use a prying tool or your fingers to remove the inner flange.
Remove the external retaining ring with a screwdriver by expanding it and then prying it out.
After removing the external retaining ring, remove (OD50 x ID42 x 0.8t) washer.
Remove the lower blade guard after removing the washer.
Thank you so VERY much! I was stuck and this was perfectly described!
