Disassembling the handle assembly will be necessary for any rewiring or switch replacement needs. Jammed switches or a damaged power cord will require these preliminary steps for repair.
Using a Torx T20 screwdriver, unscrew the five M5 x 16 mm screws.
Using the T20 screwdriver, remove the M5 x 28 mm screw.
Using a Torx T10 screwdriver, remove the M3 x 10mm screw.
Gently pull off the right side handle.
Using a hex head screwdriver, remove the two 8-16 x 1/2in screws.
Remove the one M4 x 14 mm screw using a Phillips screwdriver.
Gently lift away the switch and wires.
Press down the handle lock button.
Force-ably twist and pull away the left side handle assembly.
