When the swivel connector has worn out or started to leak the connector will need to be replaced to restore the nail gun into proper working order. You will need a open space that you can easily move the nail gun around into the proper position to remove the connector and a 8 inch adjustable wrench.
Rotate the device upside-down to have the swivel connector facing upwards.
Adjust the wrench to fit on the connector.
Turn the wrench counterclockwise to loosen the swivel connector.
Remove the swivel connector.
To reassemble your device, follow these instructions in reverse order. Make sure to apply Teflon or a adhesive such as LockTite to prevent leaks between the threads of the nail gun and new swivel connector.
