Ricoh Theta Z1 Battery Replacement
  1. Ricoh Theta Z1 Battery Replacement, Bottom: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ricoh Theta Z1 Battery Replacement, Bottom: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ricoh Theta Z1 Battery Replacement, Bottom: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Spudger to remove the sticker, starting from the reset hole.
    • The using 00-Torx remove the 3 screws at the bottom.
  2. Ricoh Theta Z1 Battery Replacement, Button side: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ricoh Theta Z1 Battery Replacement, Button side: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now remove the screw at the side with the 00-Torx screwdriver.
    • Gently remove the side pieces.
  3. Ricoh Theta Z1 Battery Replacement, Long side: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ricoh Theta Z1 Battery Replacement, Long side: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 00-Torx screw and gently slide the side piece off.
  4. Ricoh Theta Z1 Battery Replacement, Long Side: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ricoh Theta Z1 Battery Replacement, Long Side: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 4 00-Phillips screws from the long side
  5. Ricoh Theta Z1 Battery Replacement, Button Side: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ricoh Theta Z1 Battery Replacement, Button Side: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 3 00-Phillips screws from the button side
  6. Ricoh Theta Z1 Battery Replacement, Opening the Case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Ricoh Theta Z1 Battery Replacement, Opening the Case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now one part of the case can be pulled away, carefully observing the pin for the strap holder.
  7. Ricoh Theta Z1 Battery Replacement, Replacing the Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Ricoh Theta Z1 Battery Replacement, Replacing the Battery: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Ricoh Theta Z1 Battery Replacement, Replacing the Battery: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery is glued with tape to a holder, that has to be unscrewed.
JJAY
crwdns2935283:002/18/23crwdne2935283:0
170 crwdns2915208:0crwdne2915208:0
Great guide, thanks. May i know the battery detail that you use for the replacement.
Hanifah Mazlan - crwdns2934203:0crwdne2934203:0
Hi Hanifah!
The battery is called "DB-110" by Ricoh, but there are similar models with other names. If you click on the link "LI‑92B" in the parts list you get all the details.
JJAY -
👍 This was so helpful and easy to do ! Thank you 😀 * Bought DB 110 (same as for Ricoh Theta X) on Amazon for 49 €
Maximilian Paech - crwdns2934203:0crwdne2934203:0
Thank you for your post. I just called Ricoh for assistance and was referred to www.precisioncamera.com/ricoh, where I was quoted $833 to replace the battery.
I have just ordered a replacement battery on Amazon and will be doing it myself. Ricoh and PrecisionCamera can go FYT!
Mtherofdragons - crwdns2934203:0crwdne2934203:0
Where can I find the specific 00 torx screwdriver?
512SRH - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 93
crwdns2942667:0crwdne2942667:0 1,492
