I created this guide because I found nothing in the internet about changing this battery.
Use a Spudger to remove the sticker, starting from the reset hole.
The using 00-Torx remove the 3 screws at the bottom.
Now remove the screw at the side with the 00-Torx screwdriver.
Gently remove the side pieces.
Remove the 00-Torx screw and gently slide the side piece off.
Remove the 4 00-Phillips screws from the long side
Remove the 3 00-Phillips screws from the button side
Now one part of the case can be pulled away, carefully observing the pin for the strap holder.
The battery is glued with tape to a holder, that has to be unscrewed.
Great guide, thanks. May i know the battery detail that you use for the replacement.
👍 This was so helpful and easy to do ! Thank you 😀 * Bought DB 110 (same as for Ricoh Theta X) on Amazon for 49 €
Thank you for your post. I just called Ricoh for assistance and was referred to www.precisioncamera.com/ricoh, where I was quoted $833 to replace the battery.
I have just ordered a replacement battery on Amazon and will be doing it myself. Ricoh and PrecisionCamera can go FYT!
Where can I find the specific 00 torx screwdriver?
You need a Phillips #00 Screwdriver and a T4 Torx Screwdriver. You should easily get them in a set.
I bought this one in Germany: https://toom.de/p/feinmechaniker-satz-sl...
JJAY -
