The Ricoh Super 8 800oz uses an 8mm film cartridge. Inside the camera, hooks latch onto the film and rotate the reel. These hooks may break from wear and tear, material fatigue, or improperly loading the film. Replacing broken hooks will prevent the film from scratching, creasing, or tearing.
            Open the device's film cartridge door by pulling the release switch towards the eyepiece.
            Lay the device with the left side down and the door open to allow access to the film cartridge hooks.
            Using a Phillips #000 screwdriver, remove one of the screws from the rotating hooks in the center of the film bay.
            Now put your finger on the side of the screw you just removed, and take out the remaining screw with a Phillips #000 screwdriver.
            Using your fingers, gently remove the film cartridge hooks.
