Rexel Auto X60 Shredder Service
  1. Rexel Auto X60 Shredder Service, Rexel Auto X60 Shredder Service: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Auto X60 Shredder. Time for a clean out.
    • Remove from power outlet.
  2. Rexel Auto X60 Shredder Service, Remove Paper Collection Box: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rexel Auto X60 Shredder Service, Remove Paper Collection Box: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove six (6) screws. Look inside and up, they are bright in colour. These three (3) and the opposite three (3), leaving the lower six (6) untouched or the case will collapse.
    • Locate and remove six (6) recessed screws, three (3) from both sides.
  3. crwdns2935267:0crwdne2935267:0
    • Carefully place your hand inside and up onto the cutting blades. Lift up, and the upper unit will come away from the case.
    • Now vacuum up any paper dust and tiny shreds of paper. Small pliers or tweezers come in handy here.
  4. Rexel Auto X60 Shredder Service: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Rexel Auto X60 Shredder Service: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate "snubber" in the red rectangle. Notice how the round plastic pin goes into the upper plastic sleeve, if you take the further steps to "go inside" and clean, the pin needs to go back here.
    • Carefully attach sticky pad to plastic "plunger" The pads were from Lidl, so I had them lying about. The small one 10mm x 1mm thin. The added thickness makes the plunger push switch actuator down further. Thats the repair done.
    • Green circle, shows the correct placement of the Start Actuator. Plastic arm moves freely to the right of switch.
    • Please check that the cutout works when the bin is out and the top cover open.
  5. Rexel Auto X60 Shredder Service, Going In Further To Clean.: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Rexel Auto X60 Shredder Service, Going In Further To Clean.: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Rexel Auto X60 Shredder Service, Going In Further To Clean.: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove two (2) screws
    • Access by piercing label and upwards with screw driver.
    • Remove six (6) small screws to seperate the two halves. Vacuum away and use compressed air if available, (use outside).
    • Several wires hold the two halves together, just un-clip as you go.
Paul
crwdns2935283:010/09/12crwdne2935283:0
822 crwdns2915208:0crwdne2915208:0
crwdns2947412:025crwdne2947412:0
Thanks for your help. What is the cause when the Shredder will not pick up the 60X shhets and shred? Do I need to replace the 4x Rubber Rollers/ Are they available please? Thanks
Steve B New Zealand
Steve Bostin - crwdns2934203:0crwdne2934203:0
Hi Steve, The four rollers may glaze over, just wipe with a damp cloth. (Rubber cleaner or IPA alcohol, lens wipes).
Just looked at my tyre / rollers and the rear pair are ribbed with some wear and the front pair are ribbed but look in better condition. The tyre's are all tight on each wheel and not loose or slipping round.
I would make sure the shedder works in "manual" mode, hand feed a sheet in the top slot. Check the time out function works, then try a few flat sheets in the hopper tray. I thinks it works best if the paper to be shredded is not too glossy, stapled or clipped together. Also paper with hard creases / folds does not pick up well.
Do the rollers actually rotate ?
Check the pressure back plate is free to move onto the paper stack.
That's all I can think of right now.
Q. Is the problem not shredding or not picking up sheets or both ?
Paul L, South London, UK
Paul -
I've got a Rexel 100x shredder, if I power the machine on it only feeds the paper 1cm and switches off. Then I
power it on and it feeds the paper 1cm and powers off.
Hannes Du Preez - crwdns2934203:0crwdne2934203:0
Thank you for the detailed instructions. Do you perhaps have any idea where I can purchase broken gears
Antoin - crwdns2934203:0crwdne2934203:0
Unfortunately, no, just check the streets people throw them away, freecycle, eBay, Amazon and local tips some here (UK) have recycle shop.
Paul -
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 83
crwdns2942667:0crwdne2942667:0 3,534
