Revlon One-Step Hair Dryer Setting Dial Replacement
crwdns2869540:0crwdne2869540:0: 7263
5
34
118
7.263
crwdns2955950:0crwdne2955950:0: 17
crwdns2960004:015crwdne2960004:0, crwdns2960008:02crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:035crwdne2931287:0
If your hair dryer will not power on after multiple troubleshooting attempts, the setting dial may be defective. As a result, this guide will instruct users on how to properly replace the setting dial at the bottom of the hair dryer.
    1. Revlon One-Step Hair Dryer Setting Dial Replacement, Barrel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • First, remove the pink panels on each side of the handle in order to access the screws.
      • Use the iFixit opening tool to remove the pink panels.
    2. Revlon One-Step Hair Dryer Setting Dial Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Revlon One-Step Hair Dryer Setting Dial Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Revlon One-Step Hair Dryer Setting Dial Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • After removing the pink panels, there will be one visible screw on each side of the dryer handle measuring at 11mm.
      • Carefully unscrew both of these screws with a tri-point Y000 screwdriver.
      • Next, completely remove the screws out of the dryer handle.
    3. Revlon One-Step Hair Dryer Setting Dial Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Revlon One-Step Hair Dryer Setting Dial Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Revlon One-Step Hair Dryer Setting Dial Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the barrel by twisting and pulling it away from the handle of the dryer.
      • Before attempting to take the barrel off, make sure the dryer powered completely off and is cool to the touch.
    1. Revlon One-Step Hair Dryer Setting Dial Replacement, Cord and Plug: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Revlon One-Step Hair Dryer Setting Dial Replacement, Cord and Plug: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Next, slide down the air inlet and the setting dial to reveal the 11mm screws on each side of the handle at the bottom of the hair dryer.
    2. Revlon One-Step Hair Dryer Setting Dial Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • There will be one visible screw on each side of the dryer at the bottom of the handle, measuring at 11mm.
      • Store screws in a safe place, you will need them to reassemble the device later.
    3. Revlon One-Step Hair Dryer Setting Dial Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place the iFixit opening tool along the seams of the handle and pry the two pieces apart.
    4. Revlon One-Step Hair Dryer Setting Dial Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Revlon One-Step Hair Dryer Setting Dial Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Revlon One-Step Hair Dryer Setting Dial Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Once you have exposed the inside of the dryer, you will see a clear port at the very end where the cord is connected and plugged into.
      • Now, with your thumb and pointer finger gently pinch the top and bottom of the clear port.
      • Next with your free hand carefully pull the cord out of the port of the dryer handle.
    1. Revlon One-Step Hair Dryer Setting Dial Replacement, Setting Dial: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the cord is disconnected from the handle, you should be able to slide the dial setting off completely and free it from the cord.
Rory Chappuis
crwdns2935283:003/21/22crwdne2935283:0
405 crwdns2915208:0crwdne2915208:0
University of Alabama, Team 1-4, Bedsole Spring 2022 crwdns2935289:0University of Alabama, Team 1-4, Bedsole Spring 2022crwdne2935289:0
UA-BEDSOLE-S22S1G4
Referring to step 4, how do you release the first part with the metal mesh inside from the body
Richard Funnell - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This video shows very good how to dissamble the hairdryer. https://youtu.be/Qc-jcJbNQzE?si=wibfeCDW...
Tobi - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 34
crwdns2936753:030crwdne2936753:0 118
crwdns2959996:0crwdne2959996:0 7,263
