Teardown of the Revlon Hair Dryer Brush.
Remove the Two Phillips screws, one on each side.
Pull Hair Brush Portion
Do not pull apart the halves of the handle portion.
You must lightly pull apart the two halves just enough for the brush to pass
I removed the rings at the bottom before this step. That exposes the 2 screws at the bottom. Once they are removed then you can pry the 2 halves of the handle apart and the head comes off with no effort.
Definitely remove the brush after removing the bottom two (2) screws.
Twist and pull the Air Filter to remove the 2 rings. It is held in place by two lugs and holes (Circled blue on photo). Quite difficult to remove but it will come if enough force is applied
Slide the Power Indicator/Ring.
Show more on how to get the rings off. To get them off I used a flat screwdriver between the rings and the handle body to pry the rings down and off. I don't know if twisting would have gotten them to let go but that is what worked for me.
I could not get the ring off with trying to twist by hand or prying. I then used a pipe strap wrench and had it off in 5 seconds with no damage.
Nice, a photo would have been explanatory and inspiring.
Anton -
Remove final Philip screw.
Couldn’t remove air filter
Does Revlon sell a replacement brush?
