The heating element in the Revlon 473 is a coiled nichrome wire around insulated board. This repair would resolve hot air expulsion from the appliance. CAUTION: risk of potential electric shock due to live wires and damaged insulation. Be aware of sharp edges in the nichrome wire and board. Be sure to isolate your power source.
Remove the two 17.83 mm black screws located on the handle.
Separate the shell from the main component.
Check to ensure each piece is free from debris.
Remove the casing from the heating element.
Make sure that there are no breaks or debris obstructing the wires of the heating element.
To test the heating element, use a digital multimeter.
Set the multimeter to 200 under ACV (alternating current voltage).
Bring the ends of the multimeter toward the two lead wires.
If the circuit between the wires is closed, the numbers on the multimeter should keep changing.
If the numbers are not changing, replace the heating element.
If the circuit is closed, check the thermal cutout.
