Revising the brewing unit of Nivona Caferomatica
  1. Revising the brewing unit of Nivona Caferomatica, Brewing Unit maintenance: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the brewing unit from the device.
  2. Revising the brewing unit of Nivona Caferomatica: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take off the cap covering the screwhole in one corner. The cap ensures a better fit of the brewing unit.
    • Note: some versions of the brewing unit do not have this cap.
  3. Revising the brewing unit of Nivona Caferomatica: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single black Torx T10 screw fixing the opening handle.
    • Using a certain amount of force pull the opening handle out of the guidance near the red button.
    • Rotate the handle 90 degrees counterclockwise, then lift it off.
  4. Revising the brewing unit of Nivona Caferomatica: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Revising the brewing unit of Nivona Caferomatica: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unclip the upper protection panel, then remove it by lifting it up.
  5. Revising the brewing unit of Nivona Caferomatica: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove six Torx T15 screws holding together the brewing unit. The screwholes are rather deep.
    • Lift the upper half of the brewing unit up.
  6. Revising the brewing unit of Nivona Caferomatica: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Revising the brewing unit of Nivona Caferomatica: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The inside of the brewing unit ist exposed. You can see:
    • The upper piston and its gasket.
    • The funnel for the coffee grounds
    • The lower piston.
    • The hold-down clamp
  7. Revising the brewing unit of Nivona Caferomatica: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Revising the brewing unit of Nivona Caferomatica: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Revising the brewing unit of Nivona Caferomatica: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the funnel.
    • Rotate the lower piston counterclockwise and lift it off.
    • Lift off the upper piston. There ist still a hose connecting the piston to the coffee outlet. In top there ist also the downholder of the brewing unit.
    • Sometimes this downholder ist torn and the coffee leaks out of the brewing unit and does not fill your cup. Inspect the downholder for cracks. You can fix this using a special repair kit.
  8. Revising the brewing unit of Nivona Caferomatica: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Revising the brewing unit of Nivona Caferomatica: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Revising the brewing unit of Nivona Caferomatica: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the hose connecting the upper piston and the coffee outlet.
    • Remove the upper piston.
    • Remove the Torx T20 screw from the screen of the upper piston.
    • Take off the cover of the gasket and the gasket.
    • Replace the gaskets of the upper piston, the coffee outlet and water connector.
    • The lip of the piston gasket must point towards the pressure, i.e. downwards.
    • Clean thoroughly all parts. Use food-proof silicone grease to lubricate the gaskets.
  9. Revising the brewing unit of Nivona Caferomatica: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The crema-valve is located in the interior of the upper piston. It is fixed by two Torx T10 screws.
    • Remove both screws. Lift off the valve. Inspect it and clean it.
    • Note: there is another gasket on the shaft of the lower piston. Replacing it is difficult.
    • Lubricate all sliding parts with food-proof silicone grease. Verify the smooth operating of the brewing unit.
Apply all steps in reverse order to re-assemble the device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
289,185 crwdns2915208:0crwdne2915208:0
crwdns2935297:0303crwdne2935297:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 52
crwdns2936753:030crwdne2936753:0 225
crwdns2942667:0crwdne2942667:0 12,340
