crwdns2959928:0crwdne2959928:0 ↓Use this guide to replace the motherboard in a Retroid Pocket Flip handheld gaming console. The motherboard is the main circuit board of the device and connects all internal components, including the battery, display, controls, and wireless modules. If the device does not power on, fails to respond to inputs, or shows signs of internal electrical failure, the motherboard may need to be replaced.
This repair requires moderate technical experience and careful handling of internal components.
For your safety, power off the device completely and remove the microSD card before beginning this repair.
Follow Electrostatic Discharge when working inside the device to avoid damaging internal components.
Joystick removal is required before removing the motherboard.
Remove the four 5.9 mm screws from the backplate of the device with a 1.3mm hex screwdriver.
Use a plastic opening pick to carefully separate the back cover from the device.
Use a plastic spudger to carefully lift and disconnect the battery connector.
Use tweezers to disconnect the connector from its socket.
Remove the two 3.2 mm screws securing the top of the shield with a JIS #000 screwdriver.
Remove the five 3.2mm screws securing the plastic insulating shield to the motherboard.
Carefully lift and unstick the fan module using a plastic spudger, then remove it.
Remove the sticky ribbon connectors on each side of the plate with a plastic spudger.
Use a plastic spudger to carefully separate the shield from the board.
Use tweezers to unclip and remove the two ribbon cables on each joystick module.
Use a plastic spudger to lift and remove the joystick modules; they are secured with double sided tape.
Use a plastic spudger to disconnect the sliding connector by pushing on the tab to slide it out of its socket.
Use tweezers to disconnect the ribbon cables from the board.
Disconnect the coaxial connector on the left of the motherboard by positioning tweezers under the metal neck of the connector to lift it straight up.
Remove the six 5.8 mm screws from the motherboard using a JIS #00 screwdriver.
Carefully lift the motherboard out of the device.
