The circuit board is essential to the console's functions. Using Phillips #0 and Phillips #2 screwdrivers, you can replace it.
With the console on its top, remove the four 12 mm Phillips #2 screws.
Flip the console on its feet. Carefully lift the top casing from the back (where the AV/S and power ports are).
Remove the one 6 mm Phillips #0 LED circuit board screw.
Lift the top case and set aside.
Remove the 11 screws holding the circuit boards and ports in place.
Six 11 mm Phillips #2 holding the circuit boards.
Three 12 mm Phillips #2 screws holding the controller ports.
Two 7 mm Philllips #2 screws holding the back ports
Carefully lift the circuit board while holding either the AV or controller ports. Alternatively, you can hold the circuit board on its edges.
Make sure to lift the circuit board completely out of the bottom case.
I hope you show the second part were you replace the 72pin connector. Please include part source.
The 72 pin connector grabs too tightly on the cart.
Thanks.
