Use this guide to replace the dual microphone assembly in your Retina MacBook 2016.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Remove the following eight screws securing the lower case:
Two 1.8 mm P5 Pentalobe screws
Four 2.9 mm P5 Pentalobe screws
Two 6.1 mm P5 Pentalobe screws
Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
Lift the upper case and display together from the front edge and raise it to about a 45˚ angle.
Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
Close the MacBook and carefully flip it upside-down.
Lifting from the front edge, open the lower case to an angle of about 45°.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
Carefully close the MacBook and flip it over once again, so that the Apple logo faces up.
Lifting from the front edge, raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
crwdns2935267:0crwdne2935267:0Battery Blocker$3.99
As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
Remove the two screws securing the USB-C port cable bracket:
1.1 mm Phillips #00 screw
3.5 mm T5 Torx screw
Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
Use a spudger to flip open the ZIF connector retaining flap for the dual microphone assembly ribbon cable.
Disconnect the microphone assembly ribbon cable by pulling it straight out of its connector.
Remove the two 3.2 mm T5 Torx screws securing the audio jack board to the case.
Prepare an iOpener and apply heat to the upper case directly behind the microphone assembly.
Use a fine-tip probe or pick to gently peel the dual microphone assembly away from the case.
Remove the dual microphone assembly.
