If your device is having internet or network issues, the cause might be a broken wireless communication board. If this is the cause, this guide can help you to replace the broken board.
Be sure to confirm that the internet issues are due to the device itself. The wifi network it is connected to could also be the cause of the problems. To easily test this, just make sure other devices can connect to the internet properly.
Remove the water tub by gently pulling it out.
Pry off the face plate by using your finger or an opening tool.
Remove the face plate from the top cover.
Unscrew and remove the two 11.8 mm TR10 Torx screws that were revealed from the face plate being removed.
Unscrew and remove the two 11.8 mm TR10 Torx screws from the bottom of the device.
Remove the top cover from the rest of the device.
Place a halberd spudger behind the connector cable.
Use a halberd spudger to pull the connector away from the motherboard.
Insert a plastic opening tool in between the side and bottom panel.
Pry the side panel away from the bottom panel with the plastic opening tool.
Remove the side panel by pulling it away from the device.
Push in the clips which secure the board to the side panel with the plastic opening tool.
Remove the wireless communication board from the side panel.
I have an early ResMed Airsense 10 and my wireless comm board was 3G. Can this be updated with a replacement board?
The wires came out of the moden connector at the board were do I get a replacement wire?
Any luck finding one? I have the same issue.
The premise that "the device is having internet or network issues" is not based on anything factual. These machines are cellular network based.
