ResMed AirSense 10 Pump Motor Replacement
  1. ResMed AirSense 10 Pump Motor Replacement, Pump Motor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement, Pump Motor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Position the ResMed Airsense 10 with the water reservoir facing towards you.
    • Grip both the top and bottom of the water reservoir and pull it straight out and away from the device.
  2. ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position the ResMed Airsense 10 with the screen facing you to remove the front cover plate.
    • Place your finger under the indent beneath the home button and pry the front cover plate off.
    • This should only require medium pressure.
  3. ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 14mm Torx T10 screws that were exposed by removing the front cover plate.
  4. ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the device to face the bottom of the ResMed Airsense 10.
    • Remove the four 10mm Torx T10 screws, then place the screws and the plastic heater plate cover to the side.
    • Remove the remaining two 14mm Torx T10 screws.
  5. ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once you have removed the cover of the heating plate, disconnect the orange wire from the fuse.
    • Carefully pull the orange wire through the silicone gasket.
    • Fully remove the heater plate from the ResMed Airsense 10.
  6. ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the remaining two 14mm Torx T10 screws holding the frame together.
  7. ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the ResMed AirSense 10 to face the rear of the machine. The air outlet should be facing towards you.
    • Use the plastic spudger to pry the casing of the ResMed AirSense 10 off of the unit.
    • Fully remove the casing from the ResMed frame.
  8. ResMed AirSense 10 Pump Motor Replacement, Lift the modem cable off the connection: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement, Lift the modem cable off the connection: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Position the ResMed AirSense 10 with the screen facing towards you.
    • Carefully remove the 4 pin wire connector located to the left of the screen.
    • Fully remove left panel of the ResMed.
  9. ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Position the ResMed AirSense 10 with the air outlet facing you.
    • Remove the 14mm Torx T10 screw that is located between the air outlet and the front screen.
    • Remove the wires from the pump casing's hook.
    • Carefully start to remove the pump casing from the Resmed AirSense 10 until the wire connector is exposed.
  10. ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unclamp the connector for the wires that connect the pump casing to the motherboard to fully disconnect the pump.
  11. ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the pump casing with the wires facing towards you.
    • Unhook the wires from the outer most clip.
    • Then remove the plastic retainer from the pump casing.
  12. ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the blue silicone buffer to right corner.
    • Remove the wires from the remaining hooks.
  13. ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Orient the pump casing to face the outlet port.
    • Push the outlet nipple into the pump housing.
  14. ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Orient the pump casing to face the three T10 torx screws.
    • Remove the three 14mm Torx T10 screws.
    • Lift off the top of the pump casing.
  15. ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the pump assembly from the pump casing and face the pump assembly with the mounting plate facing you.
    • With the pump assembly out of the pump, there is a mounting plate that needs to be removed to access the pump.
    • There are 5 rubber ridges connecting the mounting plate to the rubber sock encasing the pump.
    • Push the ridges through the holes in the mounting plate.
  16. ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the mounting plate from the rubber sock.
  17. ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 ResMed AirSense 10 Pump Motor Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull off the rubber sock to expose the pump.
    • Do not damage the wires while removing the rubber sock.
    • The exposed pump can now be cleaned and inspected for damage.
crwdns2935229:049crwdne2935229:0
Jacey Cobb
crwdns2935283:009/16/20crwdne2935283:0
2,073 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S1-G6, Eggleston Fall 2020 crwdns2935289:0The Citadel Military College of South Carolina, Team S1-G6, Eggleston Fall 2020crwdne2935289:0
CMCSC-EGGLESTON-F20S1G6
crwdns2947412:059crwdne2947412:0
Where can i buy a replacement pump?
Shayne Braid - crwdns2934203:0crwdne2934203:0
Alibaba sells the pump. Everyone else is OOS.
Travis Verner -
got mine from aliexpress, but they are also on amazon
Tracy White -
Grabbed one on Amazon for like 90$. Worked without issues! woot, now I have my new one and this fixed my old one's motor which aged as a backup. 👍
James Tucholski -
crwdns2936751:024crwdne2936751:0 60
crwdns2936753:07crwdne2936753:0 356
crwdns2936753:030crwdne2936753:0 1,480
crwdns2942667:0crwdne2942667:0 53,722
