Replacing the hard drive of the HP 15-bs015dx laptop
  1. Replacing the hard drive of the HP 15-bs015dx laptop, Remove the Battery - Part 1: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the Battery - Part 1: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the Battery - Part 1: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Put the laptop facing down
    • Move the left battery safe lock to the right
  2. Replacing the hard drive of the HP 15-bs015dx laptop, Remove the Battery - Part 2: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the Battery - Part 2: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the Battery - Part 2: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the right battery safe lock to the left
    • This lock is harder than the previous, with this the battery should pop-up.
  3. Replacing the hard drive of the HP 15-bs015dx laptop, Remove the 6 visibles screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the 6 visibles screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the 6 visibles screws: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Philips 0 screwdriver
  4. Replacing the hard drive of the HP 15-bs015dx laptop, Remove the 4 hidden screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the 4 hidden screws: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the 4 hidden screws: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a straw to take off just enough of the rubber feet of the 4 corners
    • Use a Phillips screwdriver 0
    • Replace each rubber foot in place after removing the screws
    • You will have a total of 10 screws
  5. Replacing the hard drive of the HP 15-bs015dx laptop, Remove the DVD unit: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the DVD unit: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • It will go out easily with or without a straw
    • You can check the model number
  6. Replacing the hard drive of the HP 15-bs015dx laptop, Separate the pieces of the chassis part 1: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing the hard drive of the HP 15-bs015dx laptop, Separate the pieces of the chassis part 1: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing the hard drive of the HP 15-bs015dx laptop, Separate the pieces of the chassis part 1: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the laptop and open it
    • Use a plastic tool or a straw to separate the pieces of the chassis
  7. Replacing the hard drive of the HP 15-bs015dx laptop, Separate the pieces of the chassis part 2: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing the hard drive of the HP 15-bs015dx laptop, Separate the pieces of the chassis part 2: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing the hard drive of the HP 15-bs015dx laptop, Separate the pieces of the chassis part 2: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the laptop and separate the inferior cover of the chassis
    • Hard Drive 2.5" SATA
    • 2 RAM memory slots type DDR4 SO-DIMM
    • CPU Intel 7th generation
    • Active heat sink (fan)
    • Wireless card
    • Watch battery, 3V. CR2030
  8. Replacing the hard drive of the HP 15-bs015dx laptop, Remove the three screws from the frame: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the three screws from the frame: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the three screws from the frame: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 3 screws
    • Use a Phillips 0 screwdriver
    • Remove the frame
  9. Replacing the hard drive of the HP 15-bs015dx laptop, Remove the hard drive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the hard drive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing the hard drive of the HP 15-bs015dx laptop, Remove the hard drive: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Tilt the hard drive up
    • Disconnect the hard drive from its SATA port
    • The hard drive is 7mm high. 1TB capacity.
For re-assembly of your device, follow these instructions in reverse.
crwdns2935229:010crwdne2935229:0
crwdns2934873:0crwdne2934873:0
es en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Marcos Mora
crwdns2935283:012/17/17crwdne2935283:0
3.988 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
Disculpa, yo tengo esta laptop, mi hard drive hdd se estropeó y quisiera cambiarlo por un ssd, sin embargo no se que tipo de ssd necesito, si eres tan amable de aclararme mi duda, se agradecería.
el_kevinsillo.777 - crwdns2934203:0crwdne2934203:0
Saludos. Te toca comprar un SSD tipo SATA. Puedes revisar mi perfil, ahí tengo mis RRSS y me puede contactar.
Marcos Mora -
Great but how do you get the software to reinstall on the new hard drive?
Jared Brice - crwdns2934203:0crwdne2934203:0
That would require a whole new guide. I have some of those on my YouTube channel, link in my ifixit profile.
Bottom line: A flash drive with a Windows installer on it.
Marcos Mora -
Follow this POS guide and you WILL break the 4 mounting tabs for the hinges as NOTHING was mentioned about the 4 screws holding them down!
Mochanic - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 98
crwdns2942667:0crwdne2942667:0 8,557
