When a zipper pull breaks, or the slider simply wears out, you don’t need to replace the entire zipper. Just replace the zipper slider. This is a quick repair that can make the difference between a zipper that doesn’t work at all and one that works like it’s brand new. Determine the size of your replacement slider by looking on the bottom of your existing slider.
For replacement parts or further assistance, contact Patagonia Customer Service.
crwdns2936621:0crwdne2936621:0
Locate the top of the zipper on the side with the slider.
Peel back any fabric that is covering the zipper stop.
Carefully remove any remaining pieces of the stop using tweezers.
Slide the damaged zipper slider up and off of the zipper.
Slide the replacement slider onto the zipper.
Grab a new zipper stop.
Insert the teeth into the webbing in the same place where the old stop was located.
Use pliers to bend the metal top of the zipper stop around the edge of the webbing, poking the single tooth on the stop through the backside of the webbing.
Crimp the stop into place.
crwdns2935229:019crwdne2935229:0
crwdns2944067:011crwdne2944067:0
Where do I get the zipper stop????
How do you find the size slider(in my case 5 millimetres) and also the right size teeth that will fit into the zipper.
I used this Guide to replace the zipper slide on my wife's favorite Disney fleece jacket. I purchased my slide and the stop online. Since I'm not sure about the rules on posting vendor's info, I will say GOOGLE "nylon coil zipper slide". You can have your "zippershipped" right to your door.
AWESOME! Thanks for the pointers - I’m ready for tomorrow’s powder day!!!!
Great now how ! thank’s :)
