Replacing the Motorola E7i Power screen
    • insert fingernail or spudger between screen and coloured back at one of the top corners. Work around the perimeter disengaging the clips that hold the back of the phone on.
    • Lift the back carefully as the fingerprint scanner is attached by a fine ribbon cable. You should be able to separate the sensor from the back by lifting the diagonal attachment tabs. The adhesive is a narrow ring between the sensor and the case.
    • unscrew all 10 of the 000 philips screws. One is concealed under a tamper sticker.
    • Lift the cover away from the phone to expose the motherboard. There are some small clips around the edge, so it may come away with a jerk. If you leave the screws in the cover they will likely be thrown out at this point.
    • You can now unclip the battery (safety first!) and screen from their connections at the bottom of the motherboard.
    • remove battery - IPA? heat?
Duncan
crwdns2935283:006/29/24crwdne2935283:0
109 crwdns2915208:0crwdne2915208:0
crwdns2942667:0crwdne2942667:0 27
