Replacing the Macintosh PowerBook 1400c Monitor
    1. Replacing the Macintosh PowerBook 1400c Monitor, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the device upside down and then locate the battery latch near the front of the device.
    2. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the latch to the left to release the battery.
    3. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Continue holding the latch then gently pull the battery out of the device.
      • Place the battery in a safe location.
    1. Replacing the Macintosh PowerBook 1400c Monitor, CD-ROM Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the CD-ROM Drive latch.
    2. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the latch to the right to release the CD ROM drive.
    3. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Continue holding the latch then gently pull the CD-ROM Drive out of the device.
      • Place the CD ROM drive in a safe location.
    1. Replacing the Macintosh PowerBook 1400c Monitor, Keyboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the speaker cover.
    2. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Press firmly on each end of the speaker cover and slide it to the left.
    3. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently lift the speaker cover to remove it.
    4. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the keyboard up from the back using a spudger(wedge side).
    5. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently lift the keyboard until only the ribbon cable remains attached.
    6. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Tilt the keyboard away from the screen.
    7. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the six screws that secure the heatsink.
    8. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the six screws from the heatsink using the Philips #1 screwdriver.
    9. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the heatsink from the side closest to the laptop screen.
    10. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the heatsink.
    11. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently pull up on the beige ribbon lock until it moves a short distance on both sides to separate the ribbon cable from the connector.
    12. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Detach the ribbon cable.
    13. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the keyboard.
    1. Replacing the Macintosh PowerBook 1400c Monitor, Monitor: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Identify the right and left monitor end caps.
    2. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pry off the end caps by putting a spudger between the monitor hinge and the end cap and prying outwards.
    3. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the end cap has been loosened by the spudger, pull outwards on the end caps.
    4. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Completely remove both end caps.
    5. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Identify the 4 total screw under the end caps (2 under each end cap).
      • The two outside 16mm long screws
      • The two inside 5.4mm long screws
    6. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lay the monitor all the way back.
    7. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 4 screws using the Phillips #0 screwdriver.
    8. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:027crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Identify the center cap of the monitor.
    9. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pry the center cap off by placing the spudger between the hinge and the center cap and prying upwards.
    10. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Detach the center cap completely.
    11. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Identify the one 12.6mm long screw under the center cap.
    12. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the center screw with a Phillips #0 screwdriver.
    13. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:032crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift upwards on the metal cover under the screw.
    14. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Completely remove the metal cover.
    15. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Identify where the left and right monitor cords are attached to the logic board
      • The base of the left monitor cord
      • The base of the right monitor cord
    16. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • To detach the left monitor cord grab the left monitor cord at the base of the cord and pull vertically up.
    17. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:036crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Completely detach the left monitor cord from the logic board.
    18. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • To detach the right monitor cord grab the right monitor cord at the base of the cord and pull vertically up.
    19. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:038crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Completely detach the right monitor cord from the logic board.
    20. Replacing the Macintosh PowerBook 1400c Monitor: crwdns2935265:039crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Completely remove the monitor from the computer.
Once the monitor has been removed, to attach the new monitor follow these instructions in reverse order.
Taylor Chris
crwdns2935283:004/01/11crwdne2935283:0
241 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-39, Forte Spring 2011 crwdns2935289:0Cal Poly, Team 10-39, Forte Spring 2011crwdne2935289:0
CPSU-FORTE-S11S10G39
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 123
crwdns2942667:0crwdne2942667:0 5,412
