Replacing graphics card in pc
crwdns2936621:0crwdne2936621:0
    • Power off the PC, and disconnect the power cable from the tower.
    • Open the side panel on the PC.
    • Some panels have clips that are easy to unlatch, and others have screws that need loosening. Only the panel that gives access to the components needs removing.
    • Remove the screw(s) holding the graphics card into the slot.
    • Unclip and remove any power cables connected to the GPU.
    • Release the PCI-e slot tabs that hold the GPU in place.
    • You may have to unlock it to release the card.
    • Place the card in the slot, and press down gently until it locks into place.
    • Ensure it’s fitted into the slot correctly and that both sides sit flush. When it’s locked in correctly, the tab on the slot should hold it in place.
    • Secure the new GPU to the slot with the screw(s) that was removed earlier.
    • Reconnect the power cables to the graphics card and power supply.
    • Startup the PC.
    • When the PC starts up for the first time after installing a new graphics card, it will search for the drivers.
    • It’s always worth using the latest drivers to ensure the best functionality and compatibility with the latest games.
    • Once the new GPU is working, it’s advisable to remove any redundant drivers and software used for the old graphics card.
crwdns2935229:08crwdne2935229:0
Mark Blendy
crwdns2935283:004/04/22crwdne2935283:0
157 crwdns2915208:0crwdne2915208:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 77
crwdns2936753:030crwdne2936753:0 283
crwdns2942667:0crwdne2942667:0 31,949
