Replacing accessory belt and rollers
  1. Replacing accessory belt and rollers, Accessing the engine hood: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the trunk.
    • Put aside the trunk carpets.
  2. Replacing accessory belt and rollers, Acessing the engine compartment: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 6 T50 screws by hand or using a wrench and a socket.
    • Lift and put aside the engine hood.
  3. Replacing accessory belt and rollers, Remove the accessory belt protective cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 4 screws from the belt protection cover using a 10mm wrench.
    • Remove the protective cover from the belt.
  4. Replacing accessory belt and rollers, Release and remove the accessory belt: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing accessory belt and rollers, Release and remove the accessory belt: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Our aim is to have a colored tensioner like the one shown in the picture and like the new tensioner.
    • Use a 13mm hexagonal wrench and place it on the tensioner.
    • Turn the tensioner clockwise until you can insert a 4mm-thick pin into the hole and lock it in this position.
    • The tensioner is now locked and the accessory belt has loosened. It can now be removed.
  5. Replacing accessory belt and rollers, Replacing the tensioner roller: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing accessory belt and rollers, Replacing the tensioner roller: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single 13mm hexagonal screw from the tensioner and pull it out.
    • Fit the new tensioner roller, ensuring that the pin is correctly positioned.
    • Tighten the single new 13mm screw to 62 N/m.
    • Keep the tensioner in place for belt replacement.
  6. Replacing accessory belt and rollers, Replacing the winding roller: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing accessory belt and rollers, Replacing the winding roller: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a screwdriver to remove the cap from the winding roller.
    • Remove the single 13mm screw from the winding roller.
    • Fit the new winding roller and tighten the single new 13mm screw to a torque of 50 N/m.
  7. Replacing accessory belt and rollers, Replacing the accessory belt: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing accessory belt and rollers, Replacing the accessory belt: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing accessory belt and rollers, Replacing the accessory belt: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The idler roller must be in the slack position and tapped. If this is not the case, refer to step 2 to adjust it.
    • Install the accessory belt in the correct position, depending on whether or not the vehicle is fitted with an air-conditioning compressor. Make sure the belt passes correctly over the pulleys.
  8. Replacing accessory belt and rollers, Releasing the tensioner: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing accessory belt and rollers, Releasing the tensioner: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a 13mm hex wrench, release the tensioner roller to remove the pin and return it to the tensioned position.
    • Turn the crankshaft pulley two revolutions clockwise with a 19mm socket wrench to ensure that the belt turns and is positioned correctly.
  9. Replacing accessory belt and rollers, Replace belt cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Replace the accessory belt cover and tighten the 4x 10mm screws to 10 N/m.
    • No tightening torque is recommended by the RTA. The torque given is a suggestion.
Felicitations! You've just replaced your accessory belt and rollers!
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
AntonioTwingo
crwdns2935283:008/24/22crwdne2935283:0
7 268 crwdns2915208:0crwdne2915208:0
crwdns2935297:044crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Hi! Is this good for SCe 75 engines too? I got a Dacia Sandero II with a B4D 411 engine and i was wondering if i could use this guide to change my parts too
Árpád Kis - crwdns2934203:0crwdne2934203:0
Hi ! This tutorial is not applicable to your B4D 411 engine, part number 8201704417. The belt routing on this engine looks very different from the pictures I found online.
Other than than, many parts are different on this engine, including the injectors and all.
However, you might find some useful information on those links:
https://www.catcar.info/renault/?lang=en... (various schematics)
https://www.youtube.com/watch?v=IoF0ixzo... (B4D 422, also known as B4D LS, for Low-Spec)
AntonioTwingo -
Bjr pouvez vous me dire ou ce trouve le calculateur
Lucas - crwdns2934203:0crwdne2934203:0
Bonjour,
Il y a plusieurs calculateurs dans les Twingo III. Pouvez-vous préciser quel calculateur ?
Si vous faisiez référence au calculateur moteur (ECU):
Renault Twingo III Phase 1 (2014-2019)
AntonioTwingo -
Merci bcp pour votre reponse je cherche bien l'emplacement du calculateur moteur car j'ai bien cherché coté droit du coffre dans les garnitures et je n'ai rien trouvé.
crwdns2936753:07crwdne2936753:0 46
crwdns2936753:030crwdne2936753:0 224
crwdns2942667:0crwdne2942667:0 5,433
