Replacing a ZIF Connector Locking Flap
  1. Replacing a ZIF Connector Locking Flap, Align the Locking Flap in the Correct Position: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing a ZIF Connector Locking Flap, Align the Locking Flap in the Correct Position: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • A Locking flap with the markings "DDF" and "30d" visible on the top is shown in the first photo. It is positioned in the right direction to be replaced.
    • If the locking flap is positioned the wrong way it is easy to turn it around.
  2. Replacing a ZIF Connector Locking Flap, Insert One Side of the Locking Flap: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the back of the locking flap to position it vertical to the ZIF connector.
    • Insert one side of the flap first. A slight resistance will be felt before it is positioned.
    • You have to be very gentle so as not to break it. The use of tweezers and a magnifying glass is recommended.
    • The gold pins of the connectors must fit inside the flap. The "grid" of the flap is therefore positioned between the gold pins and the silver pins.
  3. Replacing a ZIF Connector Locking Flap, Progressive Insertion of the Locking Flap: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gradually insert the flap from right to left.
    • Keep the flap in the vertical position so that it does not come out of its housing.
  4. Replacing a ZIF Connector Locking Flap, Insert the Left Side: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Finish by inserting the left side in the same way as the right side.
    • This is a delicate operation. On occasion the flap comes out of the housing. If that happens, starting over is the best option.
    • Finish by pushing the flap as far as possible inside the connector.
  5. Replacing a ZIF Connector Locking Flap, Functional Check: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing a ZIF Connector Locking Flap, Functional Check: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Verify that the flap pivots correctly without coming off its axis.
    Thank you so much, this guide saved me a lot of trouble! I undertook a battery replacement on our CEO's 2019 MacBook Pro 16" (the glued-in kind of battery). After many hours of meticulously disassembling and re-assembling the whole laptop without a hitch, this tiny clip came out of the keyboard socket and the keyboard would not work without it. Thankfully the clip and socket were not damaged so I searched here for a solution. With this guide, a scope, and two of the super-fine tweezers from ifixit I was able to put it back into place with much less difficulty than I had expected.
    info890 - crwdns2934203:0crwdne2934203:0
You can now resume reassembly where you left off.
crwdns2935229:08crwdne2935229:0
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
AlexFixeurs
crwdns2935283:006/20/15crwdne2935283:0
1,237 crwdns2915208:0crwdne2915208:0
Fixeurs crwdns2935289:0Fixeurscrwdne2935289:0
Business
crwdns2947412:07crwdne2947412:0
Bonjour
Vous pouvez me confirmer que le connecteur ne fonctionne pas sans le clapet ? Je l'ai cassé et le clavier ne marche plus.. J'ai commandé 5 connecteurs pour essayer de remettre le clapet.. Merci
Hichem Ben - crwdns2934203:0crwdne2934203:0
Bonjour. Un connecteur bien enfoncé, avec un bout de scotch pour le maintenir en place pourrait fonctionner, mais il pourrait aussi ne pas fonctionner ou tomber en panne par intermittence. Vous pouvez faire le test, dans l'attente de l'arrivée de vos connecteurs neufs, en sachant que si ça ne maarche plus, cela vient surement de là !
AlexFixeurs -
Merci pour votre réponse.
Après avoir cassé le clapet, j'ai essayé d'insérer la nappe et d'allumer, ça ne marche pas car le bouton d'allumage fait partie du clavier.. J'ai maintenu une pression avec mon doigt ça marche pour quelques boutons.. J'attends la pièce pour récupérer uniquement le clapet, j'espère que c à cause de ça (logiquement si) malgré que je n'ai pas compris son réel rôle ce clapet.. Car la nappe me semble touchée les dents du connecteur !
Pour le détail bien enfoncé je n'arrive pas à le faire il persiste 1mm de la partie blanche de la nappe à l'extérieur comme sur votre photo.. Donc le scotch si il servira qu'à maintenir la nappe en place ça ne va pas régler le problème.. Io faut maintenir la pression par le clapet
J'ai réussi à le mettre mais beaucoup de boutons ne fonctionne pas.. Je pense que j'ai abîmé la nappe à force de la manipulé..
Où peut-on ce procuré le connecteur? Spécifiquement pour un clavier macbook pro 2015 ( 30 pin )
alain - crwdns2934203:0crwdne2934203:0
My screen is off and everything I working good bit the screen is off
Mansoor - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 56
crwdns2936753:030crwdne2936753:0 306
crwdns2942667:0crwdne2942667:0 8,265
