The handle on your Patagonia Freewheeler Luggage is designed to withstand years of hard use. But sometimes the handle becomes jammed or stuck and needs to be replaced to operate properly. Fortunately, installing a replacement handle is quick and easy.
For replacement parts or further assistance, contact Patagonia Customer Service.
crwdns2936621:0crwdne2936621:0
Freewheeler handle replacement overview.
Lay your Wheeled Luggage on its back on a table.
Unzip the main zipper.
Open the main compartment of your bag until it lays flat on the table.
Unzip the the zipper in the grey lining of the bag, opening the lining as you go.
Remove the four, red Phillips #1 screws from the frame.
Remove the two black plastic retaining brackets from the frame.
Depress the button on the handle by gripping firmly.
With the button handle still depressed, pull the handle straight out of the bag.
If you are still having trouble with your handle, check the pins inside the bag.
If either pin is not retracting use a pencil, screwdriver, or other thin object to push the pin into the hole.
With the pin depressed, squeeze the handle and pull it from the bag.
crwdns2935229:05crwdne2935229:0
I depressed the pins. It worked once or twice. But now, I have to depress the pins every time to get the handle to work OR even with the pins depressed it will still not retract or if retracted it will still not open.
What is the solution?
I love this suitcase otherwise, but the handle has always been tricky needing just the right angle on the way in and having to jiggle it to get it out.
Help Patagonia!
Hi Sharon,
The solution to depress the pins was meant to be a temporary solution when your handle is stuck in the extended position. Unfortunately, it means that your handle needs to be replaced as the handle trigger mechanism and pins are not functioning properly. Contact Patagonia for a new handle. You can either call us and we will can ship you a new one and you can replace yourself, or you can go to a Patagonia Retail Store and get a new handle there, afterwhich you can use the handing guidelines for replacement. Please visit our website for phone number and to locate a store near you. Copy and paste this URL in your search engine bar or click on the link.
