Replacing a Broken/Cracked Window Blind Slat
  1. Replacing a Broken/Cracked Window Blind Slat, Window Blind Slat: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing a Broken/Cracked Window Blind Slat, Window Blind Slat: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Adjust the angle of the blinds until every slat is flat or laying horizontally using the blind's wand.
  2. Replacing a Broken/Cracked Window Blind Slat: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing a Broken/Cracked Window Blind Slat: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing a Broken/Cracked Window Blind Slat: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the damaged slat by cutting the slant halfway across its width, at the point where it is connected to the rest of the blind, with a pair of 8-inch 'Westcott' scissors.
    • Remove the damaged slat from the blind after it has been cut on both sides.
  3. Replacing a Broken/Cracked Window Blind Slat: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Choose an un-cracked slat from a part of the blind that is unaffected during normal use - preferably from the very bottom of the blind.
  4. Replacing a Broken/Cracked Window Blind Slat: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing a Broken/Cracked Window Blind Slat: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing a Broken/Cracked Window Blind Slat: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully cut the selected slat halfway across its width, at its two connected points.
    • Carefully remove the replacement slat from its old position, making sure to not extend the cut you made past halfway of the slats width.
  5. Replacing a Broken/Cracked Window Blind Slat: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing a Broken/Cracked Window Blind Slat: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing a Broken/Cracked Window Blind Slat: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully place the replacement slat it into its new position.
    • Connect the replacement slat to the support strings at the points where the cuts were made.
  6. Replacing a Broken/Cracked Window Blind Slat: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing a Broken/Cracked Window Blind Slat: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing a Broken/Cracked Window Blind Slat: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Tear off a small piece of invisible tape from the roll of tape and carefully place it over the cuts that were made on the replacement slat.
    • Apply tape over the top and bottom of the cuts, on both sides of the replacement slat.
  7. Replacing a Broken/Cracked Window Blind Slat: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing a Broken/Cracked Window Blind Slat: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Twist the wand of the window blind to test it after applying the tape to both sides of the replacement slat.
    • If the replacement slat stays in its new position then congratulations, you have completed the fix!
Moses Matovu
crwdns2935283:003/22/21crwdne2935283:0
145 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S3-G13, Saloman Spring 2021 crwdns2935289:0UMass Dartmouth, Team S3-G13, Saloman Spring 2021crwdne2935289:0
UMASSD-SALOMAN-S21S3G13
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 156
crwdns2942667:0crwdne2942667:0 7,173
