This is an easy guide to replacing the rear buttons on the Sanyo VPC-X1200.
Remove the five case screws with a Phillips #00 Screwdriver.
Five 3.5mm Phillips Screws
Gently lift up the back cover and set aside.
Use small plastic pry tool to gently remove rear button plate.
A heat gun may be used to soften the glue for easier removal.
