This guide will show you how to remove and replace the spark plugs of your Peugeot 306 1.8 16v petrol engine.
It is recommended to clean your sparkplugs when a warm start is difficult or slowing down seems unstable. Dirty sparkplugs can result in a weaker spark or even no spark at all.
The lifespan of a sparkplug varies between 30,000 to 60,000 km (18,640 to 37,280 miles), depending on the brand and use of the vehicle.
Open the engine hood of the vehicle, using the lever located bottom left of the dashboard, by the pedals.
Locate and then disconnect the car battery.
Identify the ignition coil pack connector.
Press the locking rod near the bottom to release the connector.
Disconnect the ignition coil connector.
Locate the six H4 screws on the ignition coil pack.
Use an H4 (or T30) screwdriver to unscrew the six screws.
Grip the ignition coil pack on both sides and pull it directly upwards to remove it.
Locate the four spark plug chambers.
Grab a spark plug wrench (size 16mm).
Insert the wrench into the first spark plug chamber, until you reach the bolt.
Unscrew the first spark plug, remove it from its chamber.
Continue in the same manner for the other three spark plugs.
You can now proceed to clean or replace the spark plugs.
To reinstall the spark plugs, repeat this procedure in reverse.
To reassemble your vehicle, follow the instructions in reverse order.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
