Replacing IBM ThinkPad 560z Speaker
  1. Replacing IBM ThinkPad 560z Speaker, Battery Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery release latch to the right.
    • Pull out the battery out towards the front of the device.
  2. Replacing IBM ThinkPad 560z Speaker, Upper Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 7 mm Phillips #0 screws.
    • Remove the 10 mm Phillips #0 screws.
    • Remove the 14 mm Phillips #0 screw.
  3. Replacing IBM ThinkPad 560z Speaker: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing IBM ThinkPad 560z Speaker: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the flap on the left hand side.
  4. Replacing IBM ThinkPad 560z Speaker: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing IBM ThinkPad 560z Speaker: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the plastic opening tools between the right and left sides of the latch.
    • Pry the right side of the latch, and then pry the left side to detach the laptop's cover.
  5. Replacing IBM ThinkPad 560z Speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing IBM ThinkPad 560z Speaker: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the flap on the right side.
  6. Replacing IBM ThinkPad 560z Speaker: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the plastic opening tools towards the right side of the latch.
    • Gently pry the right side out to release the top cover.
  7. Replacing IBM ThinkPad 560z Speaker: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing IBM ThinkPad 560z Speaker: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the keyboard slowly.
    • A cable connects the keyboard to the motherboard. If you are not careful, you will damage the cable.
  8. Replacing IBM ThinkPad 560z Speaker: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers or a spudger to detach the connector.
  9. Replacing IBM ThinkPad 560z Speaker: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing IBM ThinkPad 560z Speaker: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift and remove the keyboard.
  10. Replacing IBM ThinkPad 560z Speaker, Speaker: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing IBM ThinkPad 560z Speaker, Speaker: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slowly and carefully lift the speaker with your fingers.
    • The port that the speaker plugs into can be easily removed from the motherboard if not careful! Unplug the speaker with extreme caution!
  11. Replacing IBM ThinkPad 560z Speaker: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing IBM ThinkPad 560z Speaker: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to unplug the wires from the connector.
Derek Driscoll
crwdns2935283:004/15/10crwdne2935283:0
119 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 26-27, Regan Spring 2010 crwdns2935289:0Cal Poly, Team 26-27, Regan Spring 2010crwdne2935289:0
CPSU-REGAN-S10S26G27
crwdns2935297:018crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,825
