Replacing the needle is one of the quick and easy. This does not requires opening the device and can be done in a matter of minutes.
The needle is the red plastic piece on the end of the arm. The needle snugly fits over the lower portion of the head, or front end, of the arm.
While securing the end of the arm by holding the head in place, use your fingernail to push down on the front edge of the needle.
Once the needle snaps free of the head of the arm, remove the needle by pulling down. Take care to only pull on the red portion.
On the Crosley CR7002A I am having a problem with the turntable. When the tone arm is moved over any part of the record is slides back to the home position (rest). Is their any adjustment I can make to fix this? Thanks.
