Replacing Creative Zen X-Fi Battery
  1. Replacing Creative Zen X-Fi Battery, Detaching Front Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing Creative Zen X-Fi Battery, Detaching Front Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing Creative Zen X-Fi Battery, Detaching Front Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Replacing Creative Zen X-Fi Battery, Rubber Button Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The black rubber button pad can be removed by simply picking it up.
  3. Replacing Creative Zen X-Fi Battery, Button Input Chip Part 1: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Replacing Creative Zen X-Fi Battery, Button Input Chip: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
  5. Replacing Creative Zen X-Fi Battery, Access Midsection Plate: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
  6. Replacing Creative Zen X-Fi Battery, Unscrew below Button Chip: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  7. Replacing Creative Zen X-Fi Battery, Unscrew below LCD Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
  8. Replacing Creative Zen X-Fi Battery, Separating the Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to pry the battery from the midsection plate.
    • There is adhesive glue underneath the battery, so additional force might be required to separate the battery.
  9. Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the soldering joint connecting the battery wires to the power supply, marked by the letters "PS" on the motherboard.
    • Hold the battery wires in place so that access to the soldering joints is not blocked.
    • When using a soldering iron, keep your hands and fingers as far as possible from the iron's tip to avoid burning your skin.
    • Using a soldering iron, melt the solder connecting the red wire to the motherboard. Do the same action to the black wire.
crwdns2935229:05crwdne2935229:0
Westley Courchene
crwdns2935283:001/13/15crwdne2935283:0
3,410 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 85
crwdns2942667:0crwdne2942667:0 7,915
