Replacing Citroen C1 Spark Plugs
  1. Replacing Citroen C1 Spark Plugs, Introduction: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing Citroen C1 Spark Plugs, Introduction: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the engine hood of your C1, pulling the controller located below and to the left of the steering wheel.
    • Disconnect the battery.
  2. Replacing Citroen C1 Spark Plugs, Remove the air filter box 1: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing Citroen C1 Spark Plugs, Remove the air filter box 1: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Identify the air filter box.
    • Pull back the hooks to detach the air filter box.
  3. Replacing Citroen C1 Spark Plugs, Remove the air filter box 2: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacing Citroen C1 Spark Plugs, Remove the air filter box 2: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the clamp and move it up to free the sleeve.
    • Loosen the air intake pipe clamp.
  4. Replacing Citroen C1 Spark Plugs, Remove the air filter box 3: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing Citroen C1 Spark Plugs, Remove the air filter box 3: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing Citroen C1 Spark Plugs, Remove the air filter box 3: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • You can now remove the air filter box.
  5. Replacing Citroen C1 Spark Plugs, Remove the ignition coils: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing Citroen C1 Spark Plugs, Remove the ignition coils: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing Citroen C1 Spark Plugs, Remove the ignition coils: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the three bolts of the ignition coils with the help of a 10mm 6-point socket.
    • Remove the three ignition coils by pulling them upwards.
  6. Replacing Citroen C1 Spark Plugs: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can choose to unplug each ignition coil connector and place them on a workbench (taking care to identify each coil), or leave the coils plugged in and stored to the left and above the engine.
  7. Replacing Citroen C1 Spark Plugs, Remove the spark plugs: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing Citroen C1 Spark Plugs, Remove the spark plugs: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing Citroen C1 Spark Plugs, Remove the spark plugs: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab a spark plug wrench (size 16mm)
    • Insert the wrench into the first spark plug chamber, until you reach the bolt.
    • Certain spark plug wrench are equipped with a rubber joint to help with extracting the spark plug. It is therefore necessary to apply light pressure to correctly reach the spark plug's bolt.
    • Unscrew the first spark plug, then remove it from its chamber.
  8. Replacing Citroen C1 Spark Plugs, Remove the spark plugs: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacing Citroen C1 Spark Plugs, Remove the spark plugs: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacing Citroen C1 Spark Plugs, Remove the spark plugs: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue in the same manner for second and third spark plugs.
  9. Replacing Citroen C1 Spark Plugs, Clean and replace the spark plugs: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can now proceed to clean or replace the spark plugs.
    • The cleaning of a spark plug can be done with contact cleaner and a brass brush.
    • To reinstall the spark plugs, repeat this procedure in reverse.
    • When reinstalling, be sure to rest the spark plug as straight as possible, to align the thread axes of each spark plug. The recommended tightening torque is 29Nm (21.4 lbft)
To reassemble your vehicle, follow the instructions in reverse order.
crwdns2935229:05crwdne2935229:0
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934883:0Anniecrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Subject42
crwdns2935283:008/28/14crwdne2935283:0
2,930 crwdns2915208:0crwdne2915208:0
Can you pls advice the correct gap for the sparkplug.
Kind regards.
roedoe - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 32
crwdns2936753:030crwdne2936753:0 159
crwdns2942667:0crwdne2942667:0 11,714
