Follow the steps in this guide to replace your broken central fan in your projector.
Remove the five Phillips screws on the bottom of the projector.
Remove the Phillips screw on the back of the projector.
Pry the sides of the case off using your fingers.
Pop the tabs connecting the rest of the case together by running your fingers underneath the edges.
Remove the metal plate covering the circuit board by removing the four Phillips screws.
Unplug the six cables by gently pulling up on the cable's connector.
Remove the single Phillips screw on the circuit board.
Gently pull up on the circuit board to remove it.
Remove the two Phillips screws.
Lift up on the black plastic casing around the light bulb and remove it from the projector.
Disconnect the power supply from the light bulb by gently pulling on the two metal tabs attached to it.
Remove the three screws circled in red that are holding the heat sink to the bottom part of the case.
Lift the lens/light bulb combo out of the case.
Remove the Phillips screw.
Slide the plastic piece on the left side of the fan out of its position.
Remove the two screws.
Lift the fan out of the case.
Remove the two connectors holding the fan to the metal frame.
Insert a flat head screw driver or other prying tool under the head of the connector and gently pry up.
Insert the new fan in place of the old one.
crwdns2917034:0crwdne2917034:0
Excellent work. I followed all the steps.
