This guide will take you through the steps necessary to replace your Jeep's oil filter.
Let your Jeep cool down by leaving it off for 30 minutes.
Locate the oil filter. It is a cylindrical dome on the bottom side of the engine.
Use an oil filter wrench to loosen the oil filter. Twist it to the left to remove the filter.
We did not have the correct wrench available while making this guide.
Once loosened, unscrew and remove the filter with your hand.
Let all of the oil drain from the vehicle.
After the oil is drained, begin to hand screw the new oil filter into place.
Use the oil filter wrench to tighten the oil filter until it is secure. This will prevent leaking.
Once the new oil filter is secure locate the oil cap on the engine.
Unscrew and add 6 quarts of 5W-30 type synthetic engine oil.
Replace the oil cap and the installation is complete!
With a new oil filter your engine will remain healthy and run more efficiently.
