Remove the screws.
Lift the cover.
Disconnect the battery your fingers.
The orange squares indicate the zones we will focus on.
Unplug the screen cable.
Unscrew the screw of the cover and those of the hinge. Remove the cover.
Unscrew the screw of the cover, and those of the hinge. Remove the cover.
Unplug the Wifi cables.
Unplug the camera cable.
Open the two hinges.
Remove the upper case, separating it from the screen.
Using a hair dryer, blow hot air around the screen to soften the frame's adhesive.
Remove the upper frame of the screen.
To reassemble your device, follow the instructions in reverse order.
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
