Replacement of the ventirad on the Dell XPS 13 9380
  1. Replacement of the ventirad on the Dell XPS 13 9380, Remove the back panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacement of the ventirad on the Dell XPS 13 9380, Remove the back panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacement of the ventirad on the Dell XPS 13 9380, Remove the back panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Torx T5 driver to unscrew the eight screws securing the back panel.
    • Use a spudger to pry up and loosen the back panel.
    • Lift the back panel up slightly from the non-hinged edge.
    • Pull the back panel away from the hinged edge, wiggling it back and forth to loosen the clips.
    • When the back panel clips are free, remove the back panel.
  2. Replacement of the ventirad on the Dell XPS 13 9380, Remove the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacement of the ventirad on the Dell XPS 13 9380, Remove the battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the cable from the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the four screws (M2 x 2) securing the battery.
    • Remove the screw (M1.6 x 4) securing the battery.
    • Remove the battery from its recess.
  3. Replacement of the ventirad on the Dell XPS 13 9380, Remove the ventirad: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • We removed or disconnected the battery to avoid any electrical discharge.
    • To ensure maximum processor cooling, do not touch the heat transfer areas of the ventirad. Grease on the fingers can reduce the heat transfer capabilities of the thermal paste
    • 1- Remove the 4 screws (M2x3) that attach the ventirad to the motherboard.
    • 2- Lift the ventirad and remove it from the motherboard.
To reassemble your device, follow the instructions in reverse order.
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934883:0Schwarzercrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Schwarzer
crwdns2935283:008/07/19crwdne2935283:0
5 200 crwdns2915208:0crwdne2915208:0
crwdns2935297:013crwdne2935297:0
i.Fixit FR Team crwdns2935289:0i.Fixit FR Teamcrwdne2935289:0
Community
crwdns2935297:040crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,456
