Replacement of the display on a Dell XPS 13 9380
  1. Replacement of the display on a Dell XPS 13 9380, Remove the back panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacement of the display on a Dell XPS 13 9380, Remove the back panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacement of the display on a Dell XPS 13 9380, Remove the back panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Torx T5 driver to unscrew the eight screws securing the back panel.
    • Use a spudger to pry up and loosen the back panel.
    • Lift the back panel up slightly from the non-hinged edge.
    • Pull the back panel away from the hinged edge, wiggling it back and forth to loosen the clips.
    • When the back panel clips are free, remove the back panel.
  2. Replacement of the display on a Dell XPS 13 9380, Remove the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacement of the display on a Dell XPS 13 9380, Remove the battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the cable from the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the four screws (M2 x 2) securing the battery.
    • Remove the screw (M1.6 x 4) securing the battery.
    • Remove the battery from its recess.
  3. Replacement of the display on a Dell XPS 13 9380, Display: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 1- Remove the screw (M1.6 x 3) that attaches the WiFi card and cable holder from the webcam to the motherboard. 2- Remove the WiFi card and cable holder.
    • 3- Disconnect and lift the webcam cable from the motherboard, removing the adhesive tape that attaches the webcam cable to the fans.
    • 4- Remove the two screws (M1.6 x 2.5) that attach the display cable holder to the motherboard. 5- Then remove everything.
    • 6- Disconnect the screen connection from the motherboard.
  4. Replacement of the display on a Dell XPS 13 9380: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacement of the display on a Dell XPS 13 9380: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 7- Disconnect the antenna cables from the motherboard.
    • 8- Remove the four screws (M2.5 x 4) that fix the hinges of the screen.
    • 9- Place the back of the computer screen on a clean and level surface, then open the computer at a 90-degree angle.
    • 10- Gently slide and lift the screen off the rest of the computer.
To reassemble your device, follow the instructions in reverse order.
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934883:0Schwarzercrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Schwarzer
crwdns2935283:008/07/19crwdne2935283:0
5,200 crwdns2915208:0crwdne2915208:0
crwdns2935297:013crwdne2935297:0
i.Fixit FR Team crwdns2935289:0i.Fixit FR Teamcrwdne2935289:0
Community
crwdns2935297:040crwdne2935297:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 4,635
