Replacement of fans on the Dell XPS 13 9380
  1. Replacement of fans on the Dell XPS 13 9380, Remove the back panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replacement of fans on the Dell XPS 13 9380, Remove the back panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replacement of fans on the Dell XPS 13 9380, Remove the back panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Torx T5 driver to unscrew the eight screws securing the back panel.
    • Use a spudger to pry up and loosen the back panel.
    • Lift the back panel up slightly from the non-hinged edge.
    • Pull the back panel away from the hinged edge, wiggling it back and forth to loosen the clips.
    • When the back panel clips are free, remove the back panel.
    You should be careful when removing the back panel as there also two clips on its back where the air ducts lie. If you are quick to remove it you may tear the air ducts which are quite (unreasonably) fragile given the fact they are plastic. I was unfortunate and I broke two of them so I had to use some duct tape as a minor gap would be visible between the back panel and the plastically covered air ducts. Other than that, it’s a pain to remove the back panel but not as difficult as it sounds.
    Iraklis - crwdns2934203:0crwdne2934203:0
  2. Replacement of fans on the Dell XPS 13 9380, Remove the battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacement of fans on the Dell XPS 13 9380, Remove the battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the cable from the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the four screws (M2 x 2) securing the battery.
    • Remove the screw (M1.6 x 4) securing the battery.
    • Remove the battery from its recess.
  3. Replacement of fans on the Dell XPS 13 9380, Remove the fans: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replacement of fans on the Dell XPS 13 9380, Remove the fans: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 1- Remove the screw (M1.6 x 3) that fixes the WiFi card and the cable holder the webcam on the motherboard.
    • 2- Remove the WiFi card and the cable holder for the webcam from the motherboard.
    • 3- Disconnect and lift the webcam cable from the motherboard. You will need to remove the adhesive tape that attaches the cable.
    • 4- Disconnect the power cable from the right fan of the motherboard.
    • 5- Disconnect the power cable from the left fan of the motherboard.
    • 6- Remove the two screws (M1.6 x 3) that attach the fans to the motherboard.
    • 7- Remove the fans from the motherboard.
To reassemble your device, follow the instructions in reverse order.
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934883:0Schwarzercrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Schwarzer
crwdns2935283:008/07/19crwdne2935283:0
5.158 crwdns2915208:0crwdne2915208:0
crwdns2935297:013crwdne2935297:0
i.Fixit FR Team crwdns2935289:0i.Fixit FR Teamcrwdne2935289:0
Community
crwdns2935297:040crwdne2935297:0
I do apologise if this is a redundant question. Would the bits included with the IFIXIT Essential Toolkit be sufficient to proceed with this operation, or is a more extensive kit like the Mako used here be a necessity? Thanks for the help!
Gabriele C. - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 3,673
