This guide will help you replace the CMOS (Complementary Metal-Oxide Semiconductor) battery on a Dell G3 15-3579 Gaming Laptop.
The CMOS battery in your computer will eventually run out of power (as any non-rechargeable battery does); This could lead to your computer not giving the correct date and time, some drivers may not work, and the computer may not boot properly. Make sure that all your information is backed up before you start this guide.
Flip the laptop over to gain access to ten M2.5 x 6mm flat head screws.
Use a Phillips #0 screwdriver to unscrew all the screws.
Gently pry open the bottom cover of the laptop.
Lightly shake the connector to disconnect.
Use a spudger or plastic opening tool to pry under the battery, and push forward to pop it free.
Place the new battery in by placing it over the holder and lightly pressing down.
Reconnect the battery connector by gently pushing it in until you barely see the white.
Re-screw back on the cover.
The cover will snap back on as you screw on more screws.
When you turn back on the laptop you will have to redo your BIOS settings.
