Turn the laptop upside down. Locate a removable cover, that is screwed shut near the front right of the laptop which is upside down.
After removing the screw, using your finger slowly lift out and remove the cover.
Lift the flap
Locate two connectors on both ends of the short end. This will release the ram, if properly done the long end should slightly lift.
The ram is to be removed at a 45 degree angle.
Pull out cleanly and you have now successfully removed the ram.
