Replace/revise DeLonghi ECAM Series flow meter
  1. Replace/revise DeLonghi ECAM Series flow meter, DeLonghi ECAM back panel removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the power cord!
    • Remove all attachments such as water tank, pulp drawer, brew group.
    • Turn the machine with the back facing you.
    • Remove five Torx T20 security screws.
    • A small hurdle: These screws have a pin in the middle, so the screwdriver must have a hole.
  2. Replace/revise DeLonghi ECAM Series flow meter: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replace/revise DeLonghi ECAM Series flow meter: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift out the back.
    • The following components are immediately visible:
    • grinder
    • pump
    • flowmeter
  3. Replace/revise DeLonghi ECAM Series flow meter, Replace/revise flow meter: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replace/revise DeLonghi ECAM Series flow meter, Replace/revise flow meter: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The flow meter is located on the back of the machine.
    • First detach the upper silicone hose.
    • Pull the flowmeter straight out backwards.
    • If you don't want to replace it, the cables can remain connected.
  4. Replace/revise DeLonghi ECAM Series flow meter: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the flow meter cap a little counterclockwise.
    • Lift off the lid. Pay attention to the sealing ring in the lid. The turbine wheel becomes visible.
    • Pull off the hose at the bottom.
    • Blow into the inlet port and check that the turbine wheel spins quickly.
    • If it is blocked, clear the very thin inlet channel with a needle or similar tool.
Follow these steps in reversed order to reassemble your device
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
VauWeh
crwdns2935283:010/19/15crwdne2935283:0
286,849 crwdns2915208:0crwdne2915208:0
crwdns2935297:0303crwdne2935297:0
crwdns2947412:029crwdne2947412:0
Herzlichen Dank für die übersichtliche Anleitung! Der Tipp mit dem verstopften Flowmeter aus einem Forum und dazu diese Anleitung haben mir heute sehr geholfen. Meine DeLonghi Dinamica läuft wieder. :D Selbst ist die Frau.
Beste Grüße
Christine
info - crwdns2934203:0crwdne2934203:0
Fantastisch!!! Toller Job Christine! @VauWeh erstellt die besten Ratgeber für alles, was mit Kaffeemaschinen zu tun hat!
Fantastic!!! Great Job Christine! @VauWeh creates the best guides for anything Coffeemaker related!
oldturkey03 -
Hi,
kurz vor Weihnachten streikte unsere " PrimaDonna Class ". Ein Gau für jeden Kaffeetrinker. Schnell über Online - Shops zwei Ersatzteile besorgt. Doch sie streikte immer noch. Dann die Wasserzuleitungsschläuche gereinigt. Nein, es gab immer noch keinen frischen Morgenkaffee aus dem heimischen Automaten. Dann ging ich exakt nach Deiner Anleitung vor. Yes! Sie funktioniert wieder.
Vielen Dank für die hilfreichen Tipps und ein schönes Weihnachtsfest.
Jürgen aus Eching b. München
j. lobster - crwdns2934203:0crwdne2934203:0
Sehr schön, hoch die Tassen!
VauWeh -
crwdns2936751:024crwdne2936751:0 30
crwdns2936753:07crwdne2936753:0 156
crwdns2936753:030crwdne2936753:0 813
crwdns2942667:0crwdne2942667:0 20,552
