Replace or upgrade RAM on Asus M570D
  1. Replace or upgrade RAM on Asus M570D, Remove the case screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close the laptop, place it on its lid, and align it as shown in the image
    • There are three different screw lengths:
    • 4 x PH1 12 mm (orange)
    • 3 x PH1 10 mm (yellow)
    • 4 x PH1 7 mm (green)
    • The screws must be reinstalled in the correct position later, otherwise something can be damaged.
    • Take out the screws and sort them by length.
  2. Replace or upgrade RAM on Asus M570D, Remove the keyboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device over and open it.
    • Once the keyboard is detached, you must remove the 4 ribbon cables before you can remove the keyboard!
    • Carefully insert the Jimmy into the gap between the case and the keyboard at the lower right corner of the keyboard.
    • From this position, work your way forward by levering alternately to the left and up until the keyboard is loose on the case.
  3. Replace or upgrade RAM on Asus M570D, Unplug the keyboard cable and remove the keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replace or upgrade RAM on Asus M570D, Unplug the keyboard cable and remove the keyboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are 4 cables that must be removed!
    • Carefully open the keyboard under the touchpad, move it in the direction of the screen.
    • Use the spudger to lift the black lock on the ribbon cable and carefully pull out the cable. Repeat this for each one of the four ribbon cables.
  4. Replace or upgrade RAM on Asus M570D, Disconnect the battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replace or upgrade RAM on Asus M570D, Disconnect the battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replace or upgrade RAM on Asus M570D, Disconnect the battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the battery connector.
    • Carefully slide the metal clip (marked blue in the picture) upwards to unlock the connector.
    • Use the spudger to lift the white connector upwards.
  5. Replace or upgrade RAM on Asus M570D, Remove screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws (PH1 - 8 mm)
  6. Replace or upgrade RAM on Asus M570D, Remove the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replace or upgrade RAM on Asus M570D, Remove the battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery by lifting it upwards.
  7. Replace or upgrade RAM on Asus M570D, Disconnect the WiFi antenna: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully disconnect the two antenna cables using tweezers.
  8. Replace or upgrade RAM on Asus M570D, Remove the mounting screw of the Wi-Fi card: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the PH1 screw.
  9. Replace or upgrade RAM on Asus M570D, Remove the Wi-Fi card: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replace or upgrade RAM on Asus M570D, Remove the Wi-Fi card: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the Wi-Fi card out to the left.
  10. Replace or upgrade RAM on Asus M570D, Disconnect the ribbon cable from the motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replace or upgrade RAM on Asus M570D, Disconnect the ribbon cable from the motherboard: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip up the black lock on the socket.
    • Pull the cable out to the left
  11. Replace or upgrade RAM on Asus M570D, Disconnecting the display cable: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replace or upgrade RAM on Asus M570D, Disconnecting the display cable: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to carefully remove the adhesive tape over the display cable connector.
    • Pull the connector upwards out of the socket.
    • Use caution, the cable is glued to the circuit board!
    • Carefully detach the entire cable from the circuit board.
  12. Replace or upgrade RAM on Asus M570D, Expose the WiFi antenna cable: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully thread out the antenna cable using tweezers.
    • The antenna cable runs through a slot between the hinge and the CPU fan and may be slightly jammed there. Be sure to thread it out carefully to avoid damage.
  13. Replace or upgrade RAM on Asus M570D, Remove the screws on the left: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Always hold the screen with one hand to reduce the load on the hinges!
    • Remove the screw marked in orange. (PH1 8 mm)
    • Remove the screws marked in red (2 pcs. PH1 6 mm)
  14. Replace or upgrade RAM on Asus M570D, Remove the screws on the right: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws (2 x PH1 - 6 mm)
    • Set the display assembly aside.
  15. Replace or upgrade RAM on Asus M570D, Set the display aside: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Here you can see the removed display assembly for reference.
  16. Replace or upgrade RAM on Asus M570D, Remove the I/O board: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the I/O board and release it from its holder. Take care not to damage any adjacent cables or components.
  17. Replace or upgrade RAM on Asus M570D, Pull out the fan cable: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the fan cable toward the left side of the device.
  18. Replace or upgrade RAM on Asus M570D, Remove the mounting screw of the CPU fan: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw (PH1 - 5 mm)
  19. Replace or upgrade RAM on Asus M570D, Remove the CPU fan: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift out the fan.
    • You can clean it at the same time.
  20. Replace or upgrade RAM on Asus M570D, Disconnect the speaker: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replace or upgrade RAM on Asus M570D, Disconnect the speaker: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the speaker cable out to the left.
  21. Replace or upgrade RAM on Asus M570D, Remove screws: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws. (PH1 - 5.5 mm)
  22. Replace or upgrade RAM on Asus M570D, Remove the motherboard: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replace or upgrade RAM on Asus M570D, Remove the motherboard: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replace or upgrade RAM on Asus M570D, Remove the motherboard: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift the motherboard and pull it slightly to the left to release it from the case.
  23. Replace or upgrade RAM on Asus M570D, Insert or replace RAM module: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replace or upgrade RAM on Asus M570D, Insert or replace RAM module: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replace or upgrade RAM on Asus M570D, Insert or replace RAM module: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the RAM module at an angle into the slot and press it down gently until it clicks into place.
    • Make sure that the notch in the RAM module aligns with the tab in the slot.
Follow the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0oldturkey03crwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
buntstift
crwdns2935283:006/01/25crwdne2935283:0
1,254 crwdns2915208:0crwdne2915208:0
crwdns2935297:013crwdne2935297:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 87
