Replace Asus M570D motherboard
  1. Replace Asus M570D motherboard, Remove the case screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close the laptop, place it on its lid, and align it as shown in the image
    • There are three different screw lengths:
    • 4 x PH1 12 mm (orange)
    • 3 x PH1 10 mm (yellow)
    • 4 x PH1 7 mm (green)
    • The screws must be reinstalled in the correct position later, otherwise something can be damaged.
    • Take out the screws and sort them by length.
  2. Replace Asus M570D motherboard, Remove the keyboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device over and open it.
    • Once the keyboard is detached, you must remove the 4 ribbon cables before you can remove the keyboard!
    • Carefully insert the Jimmy into the gap between the case and the keyboard at the lower right corner of the keyboard.
    • From this position, work your way forward by levering alternately to the left and up until the keyboard is loose on the case.
  3. Replace Asus M570D motherboard, Unplug the keyboard cable and remove the keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replace Asus M570D motherboard, Unplug the keyboard cable and remove the keyboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are 4 cables that must be removed!
    • Carefully open the keyboard under the touchpad, move it in the direction of the screen.
    • Use the spudger to lift the black lock on the ribbon cable and carefully pull out the cable. Repeat this for each one of the four ribbon cables.
  4. Replace Asus M570D motherboard, Disconnect the battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replace Asus M570D motherboard, Disconnect the battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replace Asus M570D motherboard, Disconnect the battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the battery connector.
    • Carefully slide the metal clip (marked blue in the picture) upwards to unlock the connector.
    • Use the spudger to lift the white connector upwards.
  5. Replace Asus M570D motherboard, Remove screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws (PH1 - 8 mm)
  6. Replace Asus M570D motherboard, Remove the battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replace Asus M570D motherboard, Remove the battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery by lifting it upwards.
  7. Replace Asus M570D motherboard, Disconnect the WiFi antenna: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully disconnect the two antenna cables using tweezers.
  8. Replace Asus M570D motherboard, Remove the mounting screw of the Wi-Fi card: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the PH1 screw.
  9. Replace Asus M570D motherboard, Remove the Wi-Fi card: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replace Asus M570D motherboard, Remove the Wi-Fi card: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pull the Wi-Fi card out to the left.
  10. Replace Asus M570D motherboard, Disconnect the ribbon cable from the motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replace Asus M570D motherboard, Disconnect the ribbon cable from the motherboard: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip up the black lock on the socket.
    • Pull the cable out to the left
  11. Replace Asus M570D motherboard, Disconnecting the display cable: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replace Asus M570D motherboard, Disconnecting the display cable: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to carefully remove the adhesive tape over the display cable connector.
    • Pull the connector upwards out of the socket.
    • Use caution, the cable is glued to the circuit board!
    • Carefully detach the entire cable from the circuit board.
  12. Replace Asus M570D motherboard, Expose the WiFi antenna cable: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully thread out the antenna cable using tweezers.
    • The antenna cable runs through a slot between the hinge and the CPU fan and may be slightly jammed there. Be sure to thread it out carefully to avoid damage.
  13. Replace Asus M570D motherboard, Remove the screws on the left: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Always hold the screen with one hand to reduce the load on the hinges!
    • Remove the screw marked in orange. (PH1 8 mm)
    • Remove the screws marked in red (2 pcs. PH1 6 mm)
  14. Replace Asus M570D motherboard, Remove the screws on the right: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws (2 x PH1 - 6 mm)
    • Set the display assembly aside.
  15. Replace Asus M570D motherboard, Set the display aside: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Here you can see the removed display assembly for reference.
  16. Replace Asus M570D motherboard, Remove the I/O board: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully lift the I/O board and release it from its holder. Take care not to damage any adjacent cables or components.
  17. Replace Asus M570D motherboard, Pull out the fan cable: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull the fan cable toward the left side of the device.
  18. Replace Asus M570D motherboard, Remove the mounting screw of the CPU fan: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw (PH1 - 5 mm)
  19. Replace Asus M570D motherboard, Remove the CPU fan: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift out the fan.
    • You can clean it at the same time.
  20. Replace Asus M570D motherboard, Disconnect the speaker: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Replace Asus M570D motherboard, Disconnect the speaker: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the speaker cable out to the left.
  21. Replace Asus M570D motherboard, Remove screws: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws. (PH1 - 5.5 mm)
  22. Replace Asus M570D motherboard, Remove the motherboard: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Replace Asus M570D motherboard, Remove the motherboard: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Replace Asus M570D motherboard, Remove the motherboard: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift the motherboard and pull it slightly to the left to release it from the case.
Follow the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0oldturkey03crwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
buntstift
crwdns2935283:006/01/25crwdne2935283:0
1,254 crwdns2915208:0crwdne2915208:0
crwdns2935297:013crwdne2935297:0
crwdns2942667:0crwdne2942667:0 63
