Repairing a Stuck Flint Wheel on a Zippo Lighter
  1. Repairing a Stuck Flint Wheel on a Zippo Lighter, Repairing a Stuck Flint Wheel on a Zippo Lighter: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open your Zippo lighter and take the inside component out of the shell simply by pulling it out.
    • Be careful of the fluid that already might be in the lighter, it might leak out.
  2. Repairing a Stuck Flint Wheel on a Zippo Lighter: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the lighter to face the bottom of the unit and locate the brass colored screw.
  3. Repairing a Stuck Flint Wheel on a Zippo Lighter: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repairing a Stuck Flint Wheel on a Zippo Lighter: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repairing a Stuck Flint Wheel on a Zippo Lighter: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the brass screw with the flat head screwdriver
    • Unscrew the rest of the brass screw using your hand.
    • Unscrew the brass screw until it comes off and the spring beneath shows but do not take the spring all the way out.
  4. Repairing a Stuck Flint Wheel on a Zippo Lighter: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the brass screw and spring out about a centimeter or two to unhinge the steel rod located beneath the flint wheel so that the rod and the wheel are not touching.
    • If necessary, tap the unit to unhinge the steel rod
  5. Repairing a Stuck Flint Wheel on a Zippo Lighter: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Follow the steps backwards to reassemble the unit and check to see if the flint wheel is unstuck.
You have now fixed your flint wheel! Enjoy your Zippo Lighter!
crwdns2935229:033crwdne2935229:0
Joseph Yoo
crwdns2935283:004/09/15crwdne2935283:0
1,010 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 28-3, Green Spring 2015 crwdns2935289:0Cal Poly, Team 28-3, Green Spring 2015crwdne2935289:0
CPSU-GREEN-S15S28G3
crwdns2935297:013crwdne2935297:0
crwdns2947412:030crwdne2947412:0
This made the problem even worse. The flint wheel is now unstuck but it can't make any sparks whatsoever.
Nabiel Wahedi - crwdns2934203:0crwdne2934203:0
me too it will not work i did the same and now it wont make sparks
cool kid -
Did you change the flint aswell? Change the flint and put it back together, if it won’t turn after changing the flint then loosen the spring again.
Bret lauk -
You need to replace the flint itself in that case.
jayanthkumarak - crwdns2934203:0crwdne2934203:0
Wonderful instructions! AND IT WORKED! Thank you.
John Heard - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 122
crwdns2936753:030crwdne2936753:0 649
crwdns2942667:0crwdne2942667:0 160,422
