Repairing a Loose Pan Handle
crwdns2869540:0crwdne2869540:0: 30K
16
144
593
29,669
crwdns2959984:0crwdne2959984:0: 7
crwdns2959974:07crwdne2959974:0
crwdns2955944:0crwdne2955944:0: 10 - 15 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937799:0crwdne2937799:0
crwdns2862591:0crwdne2862591:0
crwdns2862592:0crwdne2862592:0
In this guide, you will learn how to fix a loose pan handle. This will be done by removing the handle, cleaning the handle base, and repairing any warps. A warp is when the metal bends out of shape. This does not work on cast iron, since the handle does not come off.
    1. Repairing a Loose Pan Handle, Repairing a Loose Pan Handle: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repairing a Loose Pan Handle, Repairing a Loose Pan Handle: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repairing a Loose Pan Handle, Repairing a Loose Pan Handle: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Identify the screw keeping the handle in place.
      • Most screws are located on the underside, and a typical pan has only one screw. If there are more, locate them as well.
      • Use a standard Phillips screwdriver to remove the screw(s).
    2. Repairing a Loose Pan Handle: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repairing a Loose Pan Handle: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repairing a Loose Pan Handle: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the handle and the metal bar to expose the base of the pan handle.
      • The base is where the full handle and the pan meet.
    3. Repairing a Loose Pan Handle: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repairing a Loose Pan Handle: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repairing a Loose Pan Handle: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Determine what kind of cleaning is required. I used a Lysol solution, which can be substituted with soap and water.
      • If there is rust or burn marks, there are two guides on iFixit by other creators that work well. Their links can be followed by their respective words.
      • Apply your cleaning solution to the base.
      • If necessary, apply cleaning solution to the handle and metal bar, as well.
      • Wipe the area until it is clean, repeat if necessary.
    4. Repairing a Loose Pan Handle: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing a Loose Pan Handle: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Identify the warp on the pan, if any.
      • Warps can impact the handle, making it loose or rest incorrectly. This can occur with even small warps, so look closely at your pan.
      • Set the pan on top of a flat cloth.
      • If the warp is going in towards the pan, lay it down with the inside of the pan facing up. If the warp is going out away from the pan, lay it down with the bottom of the pan facing up.
    5. Repairing a Loose Pan Handle: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • If you do not use cloths, you will scratch the pan when you do Step 6.
      • Cover the warp with a second cloth. We used a different dish towel.
    6. Repairing a Loose Pan Handle: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Do not hammer too forcefully otherwise the pan will warp the opposite way.
      • Hammer the warp carefully.
      • It should take 2-3 strikes for smaller warps and more than 3 for bigger warps.
    7. Repairing a Loose Pan Handle: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing a Loose Pan Handle: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Take the metal bar and place it back over the base.
    8. Repairing a Loose Pan Handle: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repairing a Loose Pan Handle: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repairing a Loose Pan Handle: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Align the handle onto the metal bar.
      • Push the handle into the metal bar socket.
      • Put the screw back in the socket.
      • Use the screw driver to tighten the screw.
      • To make sure it's not too loose, pick it up by the handle to test it. If it wobbles it is too loose, and needs to be tightened more.
Repeat this for any number of pans.
Augustus Gunnerson
crwdns2935283:002/18/20crwdne2935283:0
220 crwdns2915208:0crwdne2915208:0
UC Davis, Team S1-G2, Andersen Winter 2020 crwdns2935289:0UC Davis, Team S1-G2, Andersen Winter 2020crwdne2935289:0
UCD-ANDERSEN-W20S1G2
crwdns2936751:024crwdne2936751:0 16
crwdns2936753:07crwdne2936753:0 144
crwdns2936753:030crwdne2936753:0 593
crwdns2959996:0crwdne2959996:0 29,669
