Repairing Xbox 360 Stuck Optical Drive
  1. Repairing Xbox 360 Stuck Optical Drive, Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The first step is to remove the hard drive if one is installed. Push the button at the front of the hard drive and lift the hard drive up to remove it.
  2. Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The next step is to remove the face plate. Pull out on the right side of it (by the USB cover). There are clips that hold it in place, you just need to pop it loose.
  3. Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Next we will remove the bottom vent cover. There are three tabs on each side, use the finger of the xbox tool or the pointed end of a spudger to release them one at a time, and pull up from the front as shown in the third pic.
    don’t use the tip of your spudger. it’ll bend/go blunt and break
    M1ghty boy - crwdns2934203:0crwdne2934203:0
    alternatively use a 000 phillips if you dont have the xbox tool
    What if I accidentally broke the vent cover?, because I did
    Jacob - crwdns2934203:0crwdne2934203:0
  4. Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The other vent has two holes towards the front of the xbox. Slide the finger of the xbox tool or the pointed end of the spudger into these holes to release the front two clips. There are two additional clips that are release from the sides, lift from the front as you release those clips. The back clip on the bottom is under the rubber "foot".
  5. Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To open the front you will need to cut or peel back the Microsoft sticker. THIS WILL VOID ANY WARRANTY ON THE XBOX. Turn xbox upside down, release the four clips shown, and lift the front of the bottom cover.
  6. Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the xbox tool to release the five points under the serial number label and start to lift the cover from that side. There is a clip in the middle you also may need to release. Then use the xbox tool to release the last two points at the power connection. Lift the bottom cover off the xbox.
  7. Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the DVD eject button by releasing the clip and lifting the assembly off the front of the xbox. It has a pin to the right that it slides onto, so you may need to coax it a little bit.
  8. Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There are six #10 Torx screws that hold the upper case on. Remove these, turn the xbox over, and lift the top cover off.
  9. Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • At the front of the DVD drive, peel back the end of the tape shown first, then lift the DVD drive part way so that you can access the connections in the back. Unplug the power and data connections at the back of the DVD drive, then lift it straight up.
  10. Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now is a good time to blow the dirt out. The fan shroud has a clip in the center, you can release that with the finger of the xbox tool and lift it straight up. The fans have two clips, one above each fan, lift up on the metal lip to release them. Don't forget to unplug the electrical connector also. Clean it out and re-assemble these parts.
  11. Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the screws and cut or peel the security sticker on the side of the DVD drive (also voids the warranty). Lift off the bottom and top metal case.
  12. Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To open your tray, look under the front of it. There is a small wheel that you can use the finger of the xbox tool to rotate by pulling from right to left. (In other words, rotate clockwise as seen from above.) This will lower the laser assembly and allow you to slide the tray. Clean the rubber belt with rubbing alcohol, or replace if necessary.
    Knowing where this wheel is (to raise and lower the laser assembly) is the most useful part of this guide - even after disassembling, cleaning, and re-assembling my Xbox tray wouldn't open, but moving the wheel every time I need the tray to work does the trick. Learn where the wheel is, and watch where it ends up when the box is reassembled.
    Freddy Fred - crwdns2934203:0crwdne2934203:0
    Freddy Fred, it sounds like you need to replace the belt..it's simple to do, and you can get them for a few cents each...I bought 100 of them for 2 or 3 bucks.
    ehart13169 - crwdns2934203:0crwdne2934203:0
    I'd suggest rubbing alcohol on the gears adjacent to the belt drive as well. This was needed on my drive. Both the gears and belt needed cleaning.
    retrogamerarities - crwdns2934203:0crwdne2934203:0
    if you’re having issues with this and it wont open (probably because the belt is loose), shine a torch on the left side and youll see a gear. turn that gear anti-clockwise with a screwdriver or pokey stick and itll open
    Excellent overall instructions. The only discrepancy I encountered is that the rotation direction specified in Step 12 to unlock and open the tray is opposite that of the XBox 360 E that I just serviced. To lower the laser assembly and unlock the tray, I had to rotate the indicated pulley from left to right, i.e. counter-clockwise when viewed from above the DVD drive.
    pf burris - crwdns2934203:0crwdne2934203:0
  13. Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Clean the runners where the tray slides with rubbing alcohol as well. If it is really filthy like this one, you may want to remove the tray for a more thorough cleaning. Release the tab shown and pull the tray out and to the side.
    How do you release that clip? Do you push on the clip or pull it upwards?
    Steve Sobs - crwdns2934203:0crwdne2934203:0
    Hello, You pull up on the clip. I'm doing mine right now. I also, after getting the side with the clip on it past the plastic piece with white rubber around it, had to gently, but firmly pull on the opposite side without a clip. I pulled that side towards the side with a clip and it came out, although it took a little more force than I thought it would.
    Hope this helps!
    Daniel - crwdns2934203:0crwdne2934203:0
  14. Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Xbox 360 Stuck Optical Drive: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After cleaning, reinsert the tray into the DVD drive and make sure it slides smoothly. When you push it the whole way in, it should lock in place again. Re-assemble the DVD drive, now it is ready to go back in the xbox. Re-assemble the xbox in the reverse order, and you're ready to go!
    Fantastic easy to follow guide
    Mike Heeley - crwdns2934203:0crwdne2934203:0
To reassemble, follow the steps in the reverse order.
crwdns2935229:066crwdne2935229:0
ehart13169
crwdns2935283:001/10/13crwdne2935283:0
3,102 crwdns2915208:0crwdne2915208:0
crwdns2947412:016crwdne2947412:0
This works great nice job on the guide thanks!
Severe - crwdns2934203:0crwdne2934203:0
Very great guide! My cousins Optical Drive wouldn't open at all, so I followed the guide, cleaned everything, and reassembled it. Now it opens if you give it a little love tap after pressing the eject button. Otherwise, if a disc is in it, it works great!
Simbad - crwdns2934203:0crwdne2934203:0
I started down this process when the drive would not read a game disc or a regular music CD. Cleaning the drive out did not help, but it was good to figure out how the laser lens assembly works and how one can get the drive to eject. In my case, the laser assembly needed adjustment (by decreasing the resistance of one of the two potentiometers).
Thomas - crwdns2934203:0crwdne2934203:0
How did you fix this issue
avickers902 -
Awesome guide. 100% fix for me. was able to fix tray not opening and disc not reading all in one walkthrough. follow steps, be gentle, clean belt, clean eye, reverse steps, BAM GAME ON!
neal - crwdns2934203:0crwdne2934203:0
Great guide. My son's Xbox 360 tray jammed and a disc was stuck inside of it. I was able to follow this guide and clean the tray and put the cd tray back together and it ejects discs again. I am letting him mess with it for a few days before I put it back together otherwise I will clean it some more. Thank you for this helpful guide.
Racheal - crwdns2934203:0crwdne2934203:0
Outstanding instruction and pictures. I really screwed up my xbox trying to take it apart to replace the drive belt. On my second xbox was fortunate to find you on ask.com.
Awesome! I will pass this on to my friends.**********
Joe Roscoe - crwdns2934203:0crwdne2934203:0
Good tutorial.
Although I found it hard to pry it open in the back. I found that there are clips below the openings, and to open them you have to press the screw drive forwards and then down. It will damage a bit the openings and the clips, but nothing very noticeable. It will be just a bit coarse. The price of dealing such a abnoxious case.
Miguel - crwdns2934203:0crwdne2934203:0
I love this article. Any suggestions on "exact" type of replacement parts. Like the rubber ring? If its stretched too much, can i get any old rubber band replacement say from local hardware store etc? Or do i have to order a specific part# from M$? TIA.
Chris Fisher - crwdns2934203:0crwdne2934203:0
This didn't work it still won't le me open the tray all the way. Can anyone help me please?
makayla.miles - crwdns2934203:0crwdne2934203:0
My lense won't come up when reinserting the tray, like it's not fitting the teeth when pushing the tray... HELP!
Alejandro González - crwdns2934203:0crwdne2934203:0
Had used the card trick to pop it open but it’s constantly jammed again. There was a little dust lurking and I didn’t think this this was going to do it, think it was the rubber belt cleaned that did it. Thanks for this solution, as good as new now! Saved me €€
George Hurley - crwdns2934203:0crwdne2934203:0
Still didn't open, its not even attempting to open anymore
Tiffany Baril - crwdns2934203:0crwdne2934203:0
Been about 15 years since I last opened a 360, had one in the shop today with a sticky drive and this was exactly what I needed! Those rear clips however that secure the 2 halves of the shell are an actual nightmare, nearly snapped the lot off lol, ended up doing it with a metal ruler all the way along. Anyway, Thanks very much for the guide, invaluable!
Matt LRG - crwdns2934203:0crwdne2934203:0
Very good guide. I was able to dismantle the xbox360 and clean the 2 pulleys and rails. I am 76. Thanks, Lowry
Lowry Shaw - crwdns2934203:0crwdne2934203:0
This worked! Thank you! Mine wasn’t even very dirty, but I cleaned out all the areas I could. The band in mine looked fine, I cleaned it anyway. I thought maybe something else was wrong with mine but it worked and my 8 year old is happy.
Kadence - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 47
crwdns2936753:030crwdne2936753:0 249
crwdns2942667:0crwdne2942667:0 113,429
