Repairing Vizio Television Cable Connection
  1. Repairing Vizio Television  Cable Connection, Repairing Vizio Television  Cable Connection: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • First, remove the (20) Phillips screws from the back plate. If your television is mounted against a wall, you'll have to remove it from your wall mounting bracket as well.
    • Don't forget the 2 Phillips screws in the motherboard area (circled in red).
  2. Repairing Vizio Television  Cable Connection: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repairing Vizio Television  Cable Connection: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repairing Vizio Television  Cable Connection: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the back plate, you'll see some circuit boards. We'll be focusing on the motherboard to the right.
    • (2) Phillips screws hold down covers over your inputs.
    • Note this screw holds down both covers where they overlap.
    • The bottom cover will not move until the 2 small Phillips screws are removed.
  3. Repairing Vizio Television  Cable Connection: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Vizio Television  Cable Connection: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the covers are all removed, you'll see a big hole where the cable connection is supposed to be.
    • Proceed to solder your new connection in like I did here. If you decide to replace the entire part you'll need to remove the motherboard... We'll save that for a different thread.
  4. Repairing Vizio Television  Cable Connection: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can then put it all back together once again in reverse order and enjoy some cable TV!
crwdns2935229:014crwdne2935229:0
Ricky
crwdns2935283:009/17/13crwdne2935283:0
840 crwdns2915208:0crwdne2915208:0
TechTucson WeFixThat crwdns2935289:0TechTucson WeFixThatcrwdne2935289:0
Community
Are there pics of what needs to be done in order to solder the cable connector correctly?
MistaRite145 - crwdns2934203:0crwdne2934203:0
how can I order the part to repair the coax connector for the Vizio 32 inch tv
Steven William Schwenn - crwdns2934203:0crwdne2934203:0
how can I order the coax connector part to repair my 32 inch. Vizio TV.
WHAT part is the actual connector? Ive searched for days with NO LUCK! Its a rear mount cam twist thing;I can NOT find this part!!!!
john kowalski - crwdns2934203:0crwdne2934203:0
My vizio tv is not functioning properly. When i switch it on. The dispaly say. The tuner is not set up. Click Menu so set it up. Then, when i click the “Menu” may lumalabas na “HDTV setting”. When i click it. It will just go back to its normal form.
jpfernandez211 - crwdns2934203:0crwdne2934203:0
Where can i find the nearest Service center of Vizio here in the Philippines?
crwdns2936753:030crwdne2936753:0 47
crwdns2942667:0crwdne2942667:0 17,797
