Repairing Sony Cyber-shot DSC-W290 LCD
  1. Repairing Sony Cyber-shot DSC-W290 LCD, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Find the hatch labeled "open" on the left side of the bottom of the camera.
    • Slide the hatch in the direction that the arrow is pointing. The hatch will open outward on its own.
  2. Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the blue locking tab to release the battery.
    • Slide the battery out of the camera.
  3. Repairing Sony Cyber-shot DSC-W290 LCD, Outer Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Sony Cyber-shot DSC-W290 LCD, Outer Casing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Replace hatch and rotate camera 180 degrees. You should still be looking at the bottom of the camera.
    • Remove the four 2.5mm Phillips #0 screws.
  4. Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the camera so the left side-panel reading "5x Optical Zoom" faces you.
    • Remove the two 2.5mm Phillips #0 screws.
    • You may have to remove the screws with a pair of tweezers when the screws are almost out.
  5. Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the camera so the right side faces you.
  6. Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate camera so that the back is facing you.
    • Pull the back casing directly away from the LCD screen.
  7. Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the camera so that the left side is facing you.
    • Pull the left side-panel off of the camera.
  8. Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn camera so that the front of the camera is facing you.
    • Pull the front casing directly away from the camera.
    • The right side panel may fall off when you take the front panel off.
  9. Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the camera so that the right side is facing you.
    • Pull the right side-panel away from the rest of the camera.
  10. Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This is what your camera should look like now that you have removed the casing from all sides.
  11. Repairing Sony Cyber-shot DSC-W290 LCD, LCD Assembly: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the LCD and its casing away from the motherboard as shown.
    • Be careful not to rip out any ribbon cables.
  12. Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the small ribbon-wire by gently pulling on the small ribbon-wire where it connects with the motherboard.
    • Do not use excessive force to remove the wire because this may cause it to tear.
    Caution: Do NOT attempt to remove the logic board itself until the LCD is completely off.
    Sanat Sahasrabudhe - crwdns2934203:0crwdne2934203:0
  13. Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the large ribbon-wire by pulling on the large ribbon-wire where it connects to the motherboard.
  14. Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the LCD and its casing away from the rest of the camera.
  15. Repairing Sony Cyber-shot DSC-W290 LCD, LCD: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repairing Sony Cyber-shot DSC-W290 LCD, LCD: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repairing Sony Cyber-shot DSC-W290 LCD, LCD: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the LCD and its casing so that the screen is facing you.
    • Gently pull the control panel downward, freeing it from the small metal clips.
    • Lift the control panel away from the metal and carefully pull the ribbon-wire out as you do.
  16. Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the LCD away from the metal casing on the right side.
    • Slide the LCD to the right and away from the metal casing.
    • Carefully pull the ribbon-wire out of the opening in the metal casing.
  17. Repairing Sony Cyber-shot DSC-W290 LCD: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The LCD is now out of the camera.
William Schill
crwdns2935283:010/04/10crwdne2935283:0
225 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-54, Amido Fall 2010 crwdns2935289:0Cal Poly, Team 7-54, Amido Fall 2010crwdne2935289:0
CPSU-AMIDO-F10S7G54
donde puedo conseguir la pantalla? porque la mia se estrello :(
miguel - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 7,079
