Repairing Samsung SyncMaster 245B Power supply
  1. Repairing Samsung SyncMaster 245B Power supply, resistor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Repairing Samsung SyncMaster 245B Power supply, resistor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect power cord
    • Turn monitor face down on cloth to avoid scratches
    • Remove Stand by releasing screws around plate
    • With opener tool or screwdriver work around the edges to release the clips that hold together front bezel and back cover
    • Remove back cover
    • Remove cables to CCFL (Background illumination lamps) and front bezel buttons
    • Remove cage containing PCBs, release screws and remove SMSP PCB (Power supply with power inlet connector)
  2. Repairing Samsung SyncMaster 245B Power supply: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Caution: The circuit board contains capacitors (they look like cylinders) that can shock you if they discharge. Be careful not to touch them as you work. If possible, use a capacitor discharge probe to safely rid the capacitors of dangerous charges.
    • Red marked resistors are 68Ohm about 1Watt. Measure if they have 68Ohm and replace if not
    • Put back together and test.
crwdns2935229:09crwdne2935229:0
Thomas Widmaier
crwdns2935283:003/05/13crwdne2935283:0
2.220 crwdns2915208:0crwdne2915208:0
crwdns2935297:011crwdne2935297:0
crwdns2947412:011crwdne2947412:0
it really works again, i replaced the 3 resistor 68 ohm by 1 of 220 Ohm and 5 W.
Thanks you very much.
toran - crwdns2934203:0crwdne2934203:0
Worked for me too. Nice guide, Awesome screen :D pictures at https://lunaticcharade.wordpress.com
Petter - crwdns2934203:0crwdne2934203:0
Appreciate a lot Thomas, we owe you one my friend and also thanks to Toran for the 3 in 1 trick.
Have a good day,
Cato, Canada
Cato - crwdns2934203:0crwdne2934203:0
Please note: There are two different boards for the Samsung SyncMaster 245B Power supply. The one shown here is the BN44-00173A (Board A), the alternate one is the BN44-00195A (Board B).
There are 3 main problems with the power supply
- defective capacitors (sometimes, but not always bulged top)
- defective resistors (sometimes, but not always looking burnt)
- defective fuses, simple to check
There are reports of other defects as well! Sometimes it helps to completely resolder the power supply board. Board A is far more likely to show one of the above defects than Board B. For Board A you find much more information and repair instructions. I think Board B is the younger one (redesign of Board A) and less likely to be defective. For this reason you hardly find instructions for Board B.
Board A can still be purchased. Price is usually $60-$85 + shipping. At least some of those boards are not used but used. Read careful...
And Board A is still available from my Samsung repair center.
TerraD - crwdns2934203:0crwdne2934203:0
... continued from above
Some people report success with the above steps, but some of them had the problem showing up again after hours or days. Beside the power supply there is one main second possible reason for a defective 245B: the CCFL-tubes itself. They just wear out after many hours of usage. So if a Samsung 245B shows a black screen in 2016 take this possibility into consideration as well. There are spare CCFL tubes and LED refurbishing kits for displays on the market.
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 75
crwdns2942667:0crwdne2942667:0 17,431
