How to manually advance a stuck gear train.
Move film door slide on the left side of camera forward.
Pull film door open.
Locate small silver gear in top left corner of film bay.
Using a plastic opening tool, rotate gear downward until jam is cleared.
crwdns2935229:05crwdne2935229:0
How do you know if the jam is cleared ? I have the same camera but the problem with mine is the shutter button. Every time I press the red and black one it won't make the noise or spit out the film unless I go one button behind. Although when I do that the photo comes out black. I think the two buttons or supposed to be together so when you press the red and black button the one behind it moves in sync. I really need help on fixing it and I'm not sure if what I said made any sense but I need help.
I have this very same problem…You explained it perfectly, however, I can’t figure out how to fix it. Please someone help us!
Currently trying to fix it but after the steps it isn’t working. How do I know how many times to turn the gear?
